  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
this department is such a mess - we used to have corporate services that took care of all stationary and credit cards and accounting etc ... i used to work there looking after the departments fleet cars ...... but then with the merger they all got redundant or redeployed now each division has to do their own stationary etc ...... etc the lady that does ours is hopeless and so ive gotta go pick up some stuff thats been forgotten.
haha when i first started working as a junior i used to be in charge of stationary - and down away from everywhere in this basement thing was a stationary storeroom ..... i used to have a stock of food down there as well .... i used to go down there quite a bit to get away from everyone and hide from the boss ;)
back .....
new toyota smell brings back memories when i used to work for them - i miss that climbing in one of the cars thats not yours and just driving around with music on :) spent most of my time outta the office n on the road.
Now im cooped up in an office .... Blahhhhh ;)
haha my boss actually accused me and Scott getting up to mischeif in one of the work Celicas before cos we took so long to get it to the tinters and back ...... so we just went yeah we did sorry had to test the suspension .... of coarse nothing went on tho ..... hehe the time we took the utes out for circle work was fun tho ;)
    • I don't think the shuffle can damage the turbos. It only happens at low shaft speeds and loads. It's just annoying (to some people - others are tickled by the effect) and it quite possibly reduces spool performance a little bit.
    • Oh dear. The panel beating needs to be done before the filler work. Do you have a photo of the dent before you started? Hard enough to not flex and only hit the high spots?  What do you mean it was just temporary?
    • Can u check this way it works for power supply?
    • These coils draw 10amps that what i read online
    • I appreciate the detailed explanation, think I understand now. I spent the better part of last night reading what I could about shuffle and potential solutions. I had replaced the OEM twin turbo pipe with an alternate Y pipe that is separated further away from the turbo. The current one is from HKS and I had a previous pipe that was separated even further away, both have shuffle. I had heard that a divider can be welded in to the OEM pipe to remove turbulence, and figure that aftermarket pipes that are more separated would achieve the same thing. From what I read, most people with -10 turbos get shuffle due to their size, though it's a bit less common with -5s on a standard RB26. I think Nismoid mentioned somewhere it's because OEM recirculation piping is common in Australia with -5 cars. It seems that the recommendation tends to vary between a few options, which I've ordered in what I think is most feasible for me:  1. Retune the MAP or boost controller to try to eliminate shuffle 2. Install OEM recirculation piping 3. Something called a 'balance pipe' welded onto the exhaust manifolds. I don't know if kits for this are available, seems like pure fabrication work 4. simply go single turbo My current layout is as follows: Garrett 2860 -5s HKS Racing Suction intake MAF delete pipes HKS racing chamber intake piping hard intercooler piping,  ARC intercooler HKS SSQV BOV and pipe Haltech 2500 elite ECU and boost solenoid/controller HPI dump pipes OEM exhaust manifolds HKS VCAM step 1 and supporting head modifications Built 2.6 bottom end All OEM recirculation piping was removed, relevant areas sealed off I'll keep an eye out for any alternative solutions but can get started with this.  Only other question is, does shuffle harm the turbo (or anything else)? It seems like some people say your turbo shafts will explode because of the opposing forces after a while and others say they just live with it and adjust their pedal foot accordingly.
