I r sick :mad: went down south for a few days and came back with a cold :P Getting over it now though I'm armed with the codral cold and flu tablets... *sigh* might go see steve and grant tomorrow and see if they can start preparing my turbo so the car isnt in there for long. the shirt rocks liz... good effort with the logo :)
  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
