  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
Bel my ex was salesrep and we worked together .... so half ur theory is proven .... but still i can understand the bullshit they go thru after all the tyrekicking dreamers i had look at my ZX .... after a while u get sooo sick of it. Besides they arent there to be nice - they are there to make money like the rest of us.
Oi Liz wanna go drifting in Marks drift pig :) ...... invitations there gurl haha :)
haha they are so expensive for a piece of rubber ..... mine werent tightened enough and they squeeled for ages - u could here my car starting from a block away!!
hehe i did a bit of a drift round a corner today .... well the back end was sliding out slightly ..... think the guy in the car beside me was a bit shocked - specially when my front end starts to face his side door haha ..... that was fun :)
yeah true - but i dont know anyone that can be happy to see people 24/7 ......
hehe it was actually me that used to go angry at the salesreps .... they were constantly feeling my wrath ...... they are such idiots sometimes! they try to bend the rules for a sale and therefore made my life very difficult!
My car has a better power to weight cos I dropped an rb25det into an r32 which weighs much less (and its been slightly weight reduced-weighs about 1240kg now). Also your diff gear ratios are different, r32's have 4.3:1, =Quicker acceleration. Theres heaps you can do (without increaasing power) to make your car heaps quicker.
yeah i have lost it quite a few times in the ZX .... im more careful in the Skyline ..... cos i bent something in the ZX .... castor rods or something like that from losing it into a ditch ..... and it doesnt handle as well because of it.
haha Liz sounds like when i just had my R33 and talking to Gavin at work and he goes lift the bonnet cos i could do some cheapo things to make it faster for ya ..... then he discovered the bleed valve ..... didnt even know i had one when i bought it :)
    • Which solenoid? Why was it changed? Again, why was this done? ...well, these wear..but ultimately, why was it changed? Did you reset the idle voltage level after fitment? I'm just a tad confused ~ the flash code doesn't allude to these items being faulty, so in my mind the only reason to change these things, would be some drive-ability issue....and if that's the case, what was the problem? Those questions aside, check if the dropping resistor is OK ...should be 11~14 ohms (TCU doesn't throw a flash code for this) ~ also, these TCU designs have full time power (to keep fault code RAM alive), and I think that'll throw a logic code (as opposed to the 10 hardware codes), if that power is missing (or the ram has gone bad in the TCU, which you can check..but that's another story here perhaps).
    • Question for people who "know stuff" I am looking at doing the new intake like the one in the picture (the pictured is designed for the OEM TB and intake plenum), this design has the filter behind the front bar, but, the filter sits where the OEM duct heads into the front bar, and the standard aperture when the OEM ducting is removed allows the filter to pulled back out of the front bar into the engine bay for servicing, a simple blanking plate is used to seal the aperture behind the filter This will require a 45° silicone hose from the TB, like the alloy pipe that is currently there, to another 45° silicone hose to get a straight run to the aperture in the front bar Question: how will it effect the tune if I move the MAF about 100-150mm forward, the red is around where my MAF is currently, and the green would be where it would end up Like this This is the hole the filter goes through  Ends up like this LOL..Cheers
    • Despite the level up question, actually I do know what that is....it is a pressure sender wire.  So check out around the oil filter for an oil pressure sender, or maybe fuel pressure near the filter or on the engine. Possibly but less likely coolant pressure sensor because they tend to be combined temp/pressure senders if you have one. Could also be brake pressure (in a brake line somewhere pre ABS) but maybe I'm the only one that has that on a skyline.
    • Pull codes via the self-diagnosis procedure. As far as I can tell this is just a sign of transmission issues but not a code unto itself.
    • Hi All, putting the engine back together and everything is perfect except have this plug left over.. any ideas what it is for and where it goes? Is on cold side under the intake plenum *note not a stock plug, as everything has been modified Cheers
