  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
haha when i went into west perth for lunch there was this commie ute at the lights with that funny guys version of the song "bitch" it was sooo occa all he needed was a sheepdog on the back and i wouldve thought i wasin Collie haha
