  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
she wont let me line it up to find out - her car is way to heavy .... its like driving a school bus compared to mine .... ZX definately beats it .... in fact my ZX scares the shit outta my mum .... Skyline - i think it would be a close race .... off the line most definately!! with my folks driving most definately!! but in a proffessional race after a while i think it would be a close call! .... im talking auto against auto here ..... Manual R33 might whip its arse.
My dad has the same as my mums but pooey yellow ..... he doesnt believe me when i say that Skylines used to race at Bathhurst .... he constantly puts my car down but in reality i think he's afraid of it and knows the truth ..... i mean if u paid 60K for a car and a 20K could beat it - you would be in denial too!!
apparently ...... saturday right? i think i may go shotgun in the passengers seat tho - all these cruises are costing me too much in petrol and my front brake pads are very low.
haha those pictures were funny - got me all excited Neo :D
    • I would just put EBC back on the "I would not use their stuff" pile and move on.
    • Can I suggest you try EBC directly again and link them to as many competitor catalogues as you can to show their listing is incorrect, eg https://dba.com.au/product/front-4000-series-hd-brake-rotor-dba42304/ If you have access to an R33 GTST VIN and your VIN, you could also use a Nissan Parts lookup like Amayama to show them the part number is different between 33 GTST and 34 GTT which may get their attention
    • So i got reply from EBC and they just this site where you can clearly see those 296mm fronts on R34 GTT. I send them photos and "quotes" that 296mm are not for 34 GTT and they are too small. But it will be very hard to return them cuz nobody here knows 100% and they just copy those EBC catalogue :-D https://ebcbrakesdirect.com/automotive/nissan/skyline-r34
