so do i... i was hoping to take a friday off this week and piss off down south to hide and get my head together.. guess that won't be happening for a while now with time off and extra $$ to spend... and no transport.. :)
poor me... hehehehe... **** i should just got shoot myself and get it over with.. LOL.. :(
  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
haha can we share the gun Cam :( ..... more economical that way. Yeah not a bad idea actually just take Friday off and go down to my folks place in Bunbury. They are going to Melbourne soon thank god!
