  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
Oil pressure gauge installing. I went for a drive, about 20km's, came home checked the oil... plenty of oil... so there shouldnt be any drama's. With the new turbo, I decided to get an aftermarket oil gauge to fill the 2nd spot in my pillar gauge mount, might give him a call see if he's not too busy.
