  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
Paul i dont think your the best person to judge it cos your suspension is so hard - that its normal to you ...... need someone with more stock like mine i think - i just know what the car is like and i appreciate that its been lowered and stuff .... but it was nowhere near like that before - i can even pinpoint the day where it changed to the way it is now.
nah tried that - on my old tyres anyway.
I would take it to a suspension shop and ask them what they think but a girl going into a shop and saying theres something wrong with her car but doesnt know what it is tends to put dollar signs in their eyes!
paul the surface u had it on didnt give me a chance to priove my point that stretch of roe hwy is a newly surfaced flat road ..... u try taking it to one of country runs ;) its no fun cos the car is bouncing like crazy vibrating .... not to mention the state of my brakes at the mo. I cant push it cos its just not safe.
my friends that i shared house with (Jodi and Rachael) would drop their cars to this mechanic they thought was ripping them off. so id pretend to be hubby and pick the car up. there was always a 'problem with the computer' when i asked for the bill. i think they were making a blokes version of teh bill!
    • I've never played with one, but I would expect that you are correct. That slot looks like it is intended to be used to unscrew the end, and the flats on the body would be better than grabbing it around the round bit with a pipe wrench. So, yeah, probably unscrews. You'll probably have to make a tool to drive in that slot.
    • A bit late but A disk S13P fit over stock R32 GTR brakes, usually A disk front, O disk rear works.
    • Or, the height of the release bearing is not correct for your combo. Start with the bleeding and checking the slave moves throughout its range when you press the pedal (2 person required), but it is possible for the height to be internally wrong too (box back off to measure.
    • Yes, there's quite a few things that can go wrong during a clutch install. Very unlikely. I have a similar clutch. They (ACS) make good gear. No, it is not normal. It is possible that you just need to bleed the clutch slave. But the new clutch will also have a more aggressive actuation force/pressure, and so your old slave cylinder might be a bit leaky or otherwise compromised, and not up to the extra force required. Or the master cylinder, same.
    • Hi...so a "development" here aswell The swap is "done" and car went "test drive" BUT it seems the clutch(maybe gearbox?) is a little bit sad? I bought this clutch kit https://justjap.com/products/xtreme-heavy-duty-organic-clutch-flywheel-kit-nissan-skyline-r31-r32-r33-push-type "Problem" is that the first gear is hard to put into and it seems that the clutch is not disengaged. It was not the problem with the old clutch...(or like sometime the first gear would not get as easy specialy when the fluid was cold) So? Can it be like...bad "install" or is the clutch wrong ((it should not have been) i done research to get the right one) Or is this "normal" with new clutch and needs to be break in?
