  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
Well Steve's brief description of it to me was that I have a very lean patch right in the middle but once you push through that in the high rpm the afr maps almost perfectly....
But if it was just chipped in japan would adding the intercooler and boost control cause the mapping to be inaccurate???
I am going to find out these mysteries soon though as I need a service.... In high RPM running high boost I am starting to notice that the power is retarding.... its hard to explain but it sometimes cough's and splutters a bit but only under high rpm with high boost....
I plan to get the general service done, that problem looked into, try to unlock the mysteries of my car and get the rust cut out of the wheel arch in the near future :D
Originally posted by MrGTST
Yeah I will drop it off to SST when I pick the shirt up then....
Don't forget Paul.... I too have a stock turbo ( as far as I am aware ;) ) and I got 285rwhp... I am not too far away from you :D
I'll buy you and Paul a pretty pink dress each then.
    • The issue now is the 'fuel cut' while driving, and when it happend, it does not stall. This, I did not test the fuel pressure while driving as I cannot with a fuel pressure gauge. I do have Nistune logs, yes. I have also replaced the MAF Sensor.   Also related to the FPG Fuel Hanger – I just realized that I need a Deutsch Crimp Tool to crimp some cables for the FPG Fuel Hanger. Need to purchase additional cables as the kit only included 2, which are for the float. FPG has not responded to my emails so far since purchasing. I thought about taking it to someone and having it done professionally, but I am reluctant since everyone I took it to messed up in some way.
    • There's a good German place in Brisbane if youre up for the drive 😛
    • The German place in Cabramatta was rock solid, fresh pretzel cooked to order back then. Then it went all quiet, after all the poker machines were removed, then I believe it closed for good. I did drive past the other week and noticed outdoor lighting a big screen, but no idea what is there now.
    • Yeah I suspect even if you hold airmass per cycle/cylinder constant if you get too far away from stock you're still going to have problems running the factory tune within the bounds of the factory load scale. Cams, different displacement/rod ratio, etc. I'm just lucky that the GTIII-SS with wastegate boost + CA compliance cats is pretty much equivalent to stock turbos. When I have actual space I can finally get it tuned and modify the fuel system for flex fuel to 100% handle any detonation concerns when cranking the boost to whatever those dinky turbos can put out.
    • I would say no, why, because my daughter, who also lives in Goulburn, hasn't recommended us going there Pity, as we miss all the German joints around in Sydney, actually, the restaurants are the only thing I really miss about Sydney, and a special mention to Ishibanboshi at Bondi Junction, their Kara-age Don is heart cloggingly deliciousness (always added a special boiled egg...or 2) 😋
