  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
Originally posted by zanda
yeah, but everything else was gentle.
Paul has a habit of making things......faster/dangerous.
Lets just say that on average micko and paul drive faster than russ and Liz.
which is not an endigtment on russ or liz, just that micko and paul are maniacs!
:D
Thanks Alex - I'll remember to keep my slow unconfident ass out of cruises.... don't want to hold you guys up or anything.
C'mon Lizzah,
I dont have any complaints - besides, Id much rather share breakfast with you than with paul :D
like I said - theres two types of cruises...
..and that wasnt the type where paul gets behind you and snow-ploughs you to the finish line!!
(thank god)
as far as unconfident etc goes - I think the hills are good for that, because you can generally find your own pace.
Always gonna get different rates of driving, but its probably dangerous to try and keep up with a car as modified as pauls when you're driving a semi-stock one.
Originally posted by Neo
Yer aidwin has been hiding. Who knows where?
Get out of the govt. U just waiting for that long service and pension plan they have. I know:)
so are you seeing him on the weekend or something??
govt - preaching to the converted. but for now it pays better than private enterprise anyways.:uh-huh:
I think Russ does a damn fine job with his N/A.... oh and me... well after ploughing through a car and 4 traffic lights and also the minor incident at that cruise.... hrrmmmm I was actually beginning to get my confidence back and I thought I did well at the cruise and even better on Friday night.
Nothing like an awesome comment on ones driving to change all that.....
Liz, like I said - comment was not about your driving ... more about Paul's.
as for micko - he's driving a GTR.
re the brekky cruise - you had fun and you didnt bin it. therefore you did a good job.
the whole point of having those cruises is to have fun. provided that you do that, it doesnt really matter how fast you're going.
    • Ok I get you. But isn’t the butterfly intake a headache with the +T?  see this is my plan so far but please advise me into the right direction.  Nistune Ecu, 1000cc Bosch injectors, TD05 or TD06 Kinugawa turbo using stock rb25det exhuast manifold, walbro fuel pump unsure of model I think it’s 450/460, spitfire coils and sparks to suit and a R35 MAF sensor and boost sensor.    I was thinking maybe do a cheap eBay plenum $400-500 or try find a stock det neo intake. I think I’d port match it so it’s getting the full capacity but open to advice please.  Thanks
    • The issue now is the 'fuel cut' while driving, and when it happend, it does not stall. This, I did not test the fuel pressure while driving as I cannot with a fuel pressure gauge. I do have Nistune logs, yes. I have also replaced the MAF Sensor.   Also related to the FPG Fuel Hanger – I just realized that I need a Deutsch Crimp Tool to crimp some cables for the FPG Fuel Hanger. Need to purchase additional cables as the kit only included 2, which are for the float. FPG has not responded to my emails so far since purchasing. I thought about taking it to someone and having it done professionally, but I am reluctant since everyone I took it to messed up in some way.
    • There's a good German place in Brisbane if youre up for the drive 😛
    • The German place in Cabramatta was rock solid, fresh pretzel cooked to order back then. Then it went all quiet, after all the poker machines were removed, then I believe it closed for good. I did drive past the other week and noticed outdoor lighting a big screen, but no idea what is there now.
    • Yeah I suspect even if you hold airmass per cycle/cylinder constant if you get too far away from stock you're still going to have problems running the factory tune within the bounds of the factory load scale. Cams, different displacement/rod ratio, etc. I'm just lucky that the GTIII-SS with wastegate boost + CA compliance cats is pretty much equivalent to stock turbos. When I have actual space I can finally get it tuned and modify the fuel system for flex fuel to 100% handle any detonation concerns when cranking the boost to whatever those dinky turbos can put out.
