  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
Aidwin RB25 a NSW boy - why u havent met :P
No Aidwin its not - but its got black packaging tape holding it together istead of the clear stuff that went yellow - at least it blends in a bit more now :(
everyone, im ross.
thanks lauren! i can finish printing now. i bought the laserjet 5si from the police auction. it has all accessories and is worth about 3500 and i paid 80 for it! it had a broken toner cartridge in it - they thought it was completely stuffed i suppose.
jokes on you - will probably cost about $400 for a new toner cart.
lol niz. like i said. dumb as dog shit. i sent her out to take some drawings to a builder, she came back and left straight away and returned again 5 mins later. i said ' whyd you go out, come back, and go out again?' she says 'oh - i forgot what i went out for and when i got back here i saw the drawings on the passengers seat and remembered'. i still laugh inside about it....
    • Not sure the US can import anything other than the C34 Stagea's, but if you can and you need to to tow, DO NOT under any circumstances get an M35 Stagea. If it is just as a family car and your country/state allows it, absolutely and definitely get an M35 (3.5L if possible as it is effectively a 350Z) over a C34.
    • Punch your VIN (nm35-xxxxxx) into Amayama.com You can see everything there quite easily.
    • Thanks for that, I'll check it all out. I can always do the brakes last anyway if its a problem.  The 16's are super cool, if they do fit I'll cruise around with them for a bit.
    • Well, that's kinda the point. The calipers might interfere with the inside of the barrels 16" rims are only about 14" inside the barrels, which is ~350mm, and 334mm rotors only leave about 8mm outboard for the caliper before you get to 350, And.... that;s not gunna be enough. If the rims have a larger ID than that, you might sneak it in. I'd be putting a measuring stick inside the wheel and eyeballing the extra required for the caliper outboard of the rotor before committing to bolting it all on.
