  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
Let me rephrase my last statement...
I would like to grant your request but I think that should be stay in the EVENT section...
I know most of us reads the EVENT, and it is event section after all and its where it should be...
sorry zanda, (I dont like to say NO to poeple) but I dotn want to clutter up WA section either...
Originally posted by GTS-t VSPEC
Nah, Niz is in Qld. She was sick of all the boy talk:D
Not i was sick of boy talk - wouldnt be in car forums. Its just i wasnt being spoken too - talking to myself wasnt very fun and i felt left out so i went elsewhere.
Thanks Brett *hugs* hehe i have now got access to bosses email and i know theres some emails in there about the new chick so im going to wait til he goes out and read thru them - see if i can get a finishing date for myself!! I cant wait ..... going back to part time temping ..... i should have enough money by then to go a month again without a fulltime job :P:D:(
    • Have you flushed the initial fluid yet? It should look like a rainbow unicorn shat glitter into it. 2nd or 3rd fluid change is when you party.
    • all brand new unit from Tomei, fluid, bearings, etc. Tomei said they call it a 1.5 lsd because its 100 percent lock up under acceleration and 50 percent under deacceleration.  as I mentioned I used their fluid, install and their break-in procedure, (alot of figure 8's) but even when driving straight, or even slowly backing out of garage for first time, (at 2 mph) then driving to and from figure 8 parking lot, each tire in the rear would sporadically grab, skip, bounce, shutter and skip, shutter back a force I could feel causing clutch to slip then grab, at any speed. shaking entire car. I removed unit, since I put stock back in and all is fine, via process of elimination, its something with the lsd unit itself. I wasn't going to beat up the entire car more or change anything else for no reason as I had a feeling something in the lsd itself was wrong as everything was fine before this alone was installed and I rechecked over everything else after first time backing out I suspected an issue. I'll probably sadly already need new tires now just from trying to drive it 5 miles and performing the figure 8 break in. but if someone has any ideas I'm all ears
    • Ok thanks..that was my second question if i can somehow bypass this even with Nistune(that is all i have right now...aparat from stock ECU. So with some aftemarket it can by "bypassed" or make it work?  I know there is Link or Haltech (mainly used). We have ECUmaster here so i will gather some info about it.
