  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
yeah when i was 18 i wanted to see how long i could stay up for. i ended up drinking a 500g jar worth of instant coffee and about 8 litres of coke was buzzing the whole time but only lasted 56 hours and 22 mins before i fell over and didnt get up.
:bahaha:
Should be. The car goes in tuesday to have old turbo removed and new turbo bolted on, new braided oil line put in and old water line blocked off. Then wednesday (maybe tuesdau arvo depends on how long it takes grant) it's off to the exhaust shop to get a custom made dump+front pipe made up with a seperate wastegate line rejoining just before the cat. Dont want no cop bait screamer :P
    • Photo quality is terrible, but there's a few things on that board that give me suspicions it has some issues. Add to that, I'm hoping the cut and exposed wires under the dash were not exposed or touching each other before you pulled that all apart.
    • Stories like this are why the immobilizer installs I've done are 100% reversible. No harness cuts.
    • update; Replaced oem starter motor with a Jaylec 70-61111 car still didn't start, moved over to the alarm system unraveled the spaghetti checked the solder end points, PCB board burn smell, wiring ends, capacitors, water damage everything looked fine restarted car vroom. restarted 5 to 6 time over an hour started put every thing back together only to not have it start any more. looks like i will be removing the alarm system next weekend.
    • Lots of people. Could be a lot of things like people have said. Either the heater hose/pipe, the turbo coolant return that wraps around the back of the engine, or a core plug. I have seen all three. If you want me to guess wildly though I would bet it's one of those hoses for the turbo coolant return. Or the brazing/welding for the Y- section has failed. Get a borescope down there to be 100% sure.
    • FWIW, I've aerated oil, and cams snapped. You can figure out the rest 🥲
