  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
afternnoon all. Anyone? Serious lack of action around here lately, or maybe I haven't been around. Should try to organise another social event. Am trying to get some tiime off work soon (stress leave), so If I get a couple of weekends off, I will try to organise a luncheon or cruise or something.
I am thinking of finding a location where we can all park in a group with heaps of space, everyone bring their tools and expertise and we just have a day where everyone is together and anyone who needs help with their cars (mechanically, stereo, electrics...) can ask, so we can all hopefully learn something from each other and get some free work done on our cars.
If we find a park with BBQ facilities, bring lots of beer, I think it would make a good day out.
Of course I am relying a lot on the good will of our more mechanically minded members... I will bring my friend Alex, who does car electrical work.
Just want to get an idea of interest before I post anything in events section.
Do you think most people will go for it? It would be really bad if we organised it and no one who knows anything turned up. If there was only one person doinh the work it would also be unfair, and everyone would be standing around with nothing to do.
If it happens we would have to confirm certain people, and have a rough agender.
    • FWIW, I've aerated oil, and cams snapped. You can figure out the rest 🥲
    • Depending on the hose, sometimes engine out is the easiest option
    • Get an inspection camera up there.
    • Yeah, but look at the margin in viscosity between the 40 and the 60 at 125°C. It is not very large. It is the difference between 7 and 11 cP. Compare that to the viscosity at only 90°C. The viscosity axis is logarithmic. The numbers at 90 are ~15 and ~35. That is about half for the 40 wt oil and <half for the 60. You give up viscosity EXPONENTIALLY as temperature rises. Literally. That is why I declare thicker oil to be a bandaid, and a brittle one at that. Keep the oil temperature under about 110°C and you should be better off.   Having said all of that, which remains true as a general principle, if you have indeed lost enough oil from the sump that the pump was seeing slightly aerated oil, then all bets are off. That would of course cause oil pressure to collapse. And 35 psi is a collapse given what you were doing to the engine. Especially if the oil was that hot and viscosity had also collapsed. And I would put money on rod or main bearings being the source of the any noise that registered as knock. Hydraulic lifters should be able to cope with the hotter oil and lower pressure enough to prvent too much high frequency noise, although I am willing to admit it could be the source.
