  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
Niz, Doesn't look like your going to get your ass over here, so you'll get niether:p
Sub, I think they make mention of it in a HPI mag or DVD, but I don't know enough about it to comment.
Rob, Cool, it should look good with a decent turbo in your engine bay:D
joe - the problem was i did think about and the visuals were a little too much!! ulesss my mind is on a gutter track .... which is highly likely
paul - it was u that was suppose to be coming over here - 8 mins remember - ive been timing its been an hour - your a grandpa driver and im off to bed ..... no soup 4 u :rolleyes:
Night All
:grouphug:
