  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
see before the avc-r was put in, i got down to 14.1
and then i got one good run one night and did a 14.01 at 10psi and then i havent been able to get close again, i did a 14.2 last time i was at willowbank, i think i need to get out and get a heap of runs in a row so i can get my launching right, cause i havent been able to do that in ages, recently
test and tunes have been rained out or way way too busy
im not sure, id have to check into it
i know i can do rpm based boost control, so for lower rpm i can have lower boost and ramp it up
to try and reduce wheel spin, im not sure about gear based, id have to read through the pile of "translated" manual that i have, which isnt exactly the easiest to understand. at the moment i got it running right, it just feels sluggish cause it runs so rich, like u set it to wastegate control, factory 7psi and it runs how its sposed to it feels so much punchier at low rpm
i know someone with the same mods or similar and he did a 13.7 first run of the night, which was much better than my 14.5 at the same night
    • I like their veal scallopini.
    • Definitely a hearty eater when we go out, I consider these meals my cheat day as I've been watching my calories in and calories out pretty hard since my little fun size stroke, I've gone from a fat boy of 89 Kg, I'm only 165cm tall/short, down to a almost semi lean 73 Kg over the last few years, I'm currently around 17% body fat which my doctor is very happy with, but, my goal is to slowly get down to and maintain 15%,so yeah, I want all of the protein, carbs, fats and sugars when I go out for a binge
    • There was a great one on Victoria Rd in Gladesville too back in the day. I can only assume GTSBoy is thinking of the mill up on the wollondilly, no restaurant there any more but they have restored the original steam engine on site and run it every few months, have an annual steampunk festival etc @The Bogan, you came to the wrong town for restaurants. we have a few reasonable asian and indian options but the Paragon is as good as it gets otherwise. That brewery is apparently just opened, been meaning to give it a go some time. The Highlands have plenty of fancy options but I suspect you are more a hearty eater than fancy eater
    • Thanks for coming back to post the update, maybe it will help out the next person!
    • Going by the intake & injectors I'd be guessing it's a DE, check the head casting number, should be 5L8 on a DET, 5L7 I think is the DE number.
