  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
Alex - im a temp - continutity isnt a issue .... im going to continue to temp probably for the rest of this year ive decided ..... got too many things going on to have a permanent job say i cant have time off here and then blah blah blah. No one gives written references anymore anyway!
Al - you're going to love this one.. just had an engineer grandstanding to me about how he is the lead on a certain aspect of the job and as a result I should respect his authoritah and the fact that I am actually doing his job in some instances doesn't really matter..
5 mins later he comes and asks me to sign something that he is responsible for?!??!?
I gave him the appropriate answer.. :D good thing I'm outta here for a week.. it's gonna take him a while to get his hearing back..
    • Not sure the US can import anything other than the C34 Stagea's, but if you can and you need to to tow, DO NOT under any circumstances get an M35 Stagea. If it is just as a family car and your country/state allows it, absolutely and definitely get an M35 (3.5L if possible as it is effectively a 350Z) over a C34.
    • Punch your VIN (nm35-xxxxxx) into Amayama.com You can see everything there quite easily.
    • Thanks for that, I'll check it all out. I can always do the brakes last anyway if its a problem.  The 16's are super cool, if they do fit I'll cruise around with them for a bit.
    • Well, that's kinda the point. The calipers might interfere with the inside of the barrels 16" rims are only about 14" inside the barrels, which is ~350mm, and 334mm rotors only leave about 8mm outboard for the caliper before you get to 350, And.... that;s not gunna be enough. If the rims have a larger ID than that, you might sneak it in. I'd be putting a measuring stick inside the wheel and eyeballing the extra required for the caliper outboard of the rotor before committing to bolting it all on.
