  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
joe Nooooo its not THAT!!
u dont get a headache with that and i said my tummy was sick not feeling like there are sharp knives being shoved thru it!
i think theres a tummy bug going round or something at moment - lotta people been having sickies.
hey im moving desks again next week ..... this one has more privacy :P:(
whats so hard about things being left in the past??? i mean why me .... why do i have to have it constantly being dragged up ...... i just want everything dead and buried for phucks sake!!!!!
my ex just rang ..... after phuck knows how long .... well february was probably last time i spoke with him ..... why? why cant he just leave it alone and disappear into the sunset like they are meant too!!!
I dont know..but If ex-rings you
1.Want some thing back
2. lonely and thinking if he can back to it...
3. want a quick root
4. Wanna know your female friend's Phone number
5. want more root
6. hardly happens, relised after sooo lone lonelyness, he got it wrong and want you back... :D
cheers
Joe
yeah well he leaves for England on Friday ...... wants a beer when he gets back ...... so its a case of good-o your pissing orff .... shit your coming back ..... he's a god damn human boomerang!
i forgot to ask what the phuck is happening to Shadow!!!! man if he has so much given that cat away he wont wanna come back cos i will be waiting a tthe airport for him with an axe!! I so forgot to ask ...... i want MY phucking cat back!!!
    • Yeah in that case, pulling the dent out. Event a very slight dent can create a lot of work filler-wise and there is a strong chance the panel won't be the factory shape when you are done (as the dent will result in a new high point created somewhere, then everything is brought up to that new high point... but the panel shouldn't be that high if that makes sense).  So you've filled and primed the panel and it is flat, why would you go back and remove the primer and add more filler?
    • Something else I have been faffing with while the car was off the road is making the AC work. Assuming the car isn't at a thermal limit the idea of having AC while waiting in line to go on track sounds delightful. I have actually been lugging around the weight of the entire system since 2018 when the RB25NEO went in without it working at all.  The main reason was in the first few events before I got around to re-gassing it the rubber hose that runs under the manifold had the factory heat wrap/sleeve fail resulting in this: ~2 years ago I purchased a complete used R32 AC line set but when I finally went to install it the line i needed was different where the expansion section is I found a local place that was able to replace the rubber section and re-crimp. They also added some modern heat sleeve to the hose Tight fit but fingers crossed this is the last physical piece of the puzzle needed
    • the top black section is bonded to the silver section with some form of rubber. I assume to isolated NVH from the box
    • Plan B? Get someone to machine up a metal bush/collar/whatever it needs to be to replace the rubber? I haven't had a close look at that part recently to have a proper feel for whether that's possible. But it might be easy.
    • I do not want to install a short shifter and the only other stock throw shifter I have seen is the Nismo "Rigid shifter" for $290 So plan A is to fill it with sikaflex to stiffen it up and hope for the best
