  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
Guest Nobel Soul
well nizy i reckons it wont be nice if it happen that the only place he finds you is on the rear view mirror, i dont care what it is, but i sure dont like being in his rear view mirror. I did some research after i heard this, and their are alot of independent guys out their that say, the xr6t has been under powered before release, while when ford tested it, they did out puts of upto 800kw. Now that is heaps for a ford
that would be a very exceptional XR6T.
Like VERY exceptional. I think he is probably yanking your chain.
the xr6t is not a particularly easy car to make really fast - because it has such a large displacement. to produce that sort of time, you're looking at 800+ ps, which would require a big turbo and some serious internal work.
the catch is, that because he throw is so long for each cylinder, he'd struggle to find rods that would put up with the sort of hammering that a high outpurt turbo would put an engine under at very high boost.
so, I call b/s on the 10 second XR6T.
Nobel what i dont understand is if your flying the flag for Ford so high .... then get dad to buy you one :P ..... we are really trying to care .... but as this is a Nissans forum we really dont give a phuck.
i know my car aint the fastest on the planet .... but it still kicks enough male butt that im more than happy :) not too mention its a Nissan!
i just dont get some people! What does he want us to do .... "a friend of a friend who knows some guy at the other side of the country may have a 10sec XR6T" ...... so? want us to worship the ground you walk on ..... or sell all our cars for Fords now :P ... you are trying to achieve what??
Guest Nobel Soul
zanda, well i did take it all with a pinch of salt, so i did my research and here is what i found...
240kW at 5250rpm and 450Nm from 2000-4500rpm
6psi turbo pressure
that is what its set to as the standard, and the compression ratio is 8.7:1. Being a 4 L engine it has alot more potential. I just wonder what ford got out of it before it reached danger zone.
capa http://www.capa.com.au/xr6.htm has already released kits that boost it to 350kw and they are working on a 380kw which they think they can achieve no sweat.
I also heard from a ford guy that the trubo can be set as high as 32psi, but i still got to verify that.
There is alot of work happening on it, heaps of people in the east are trying things out on it.
I am just waiting to see if those numbers are true.
Guest Nobel Soul
I was just sharing some news i heard, after all this is a car forum, and the filter doesnt seem to be set to pick out holden and ford and Maybe you have missed it all this time.
NO I DONT SUPPORT FORD, to me they just stupidly designed, the fools add weight then they think, oh shit its laggin so more fuel ahh thats better.
I hope that settles your misery nizmo, i suggest you look into something more entertaining if this bores you so much.
Gad daaaaaaaiyum some people
    • So sadly the fuel pump etc was not it. The pump and filter is new and it is still cutting around 4000 rpm. A read something about ABS/TCS (engine is from stagea and ECU too so no TCS) and i dont know for 100% that my car has ABS. It has ABS "cube" in engine bay but i dont think it works(or at least from my braking experience). Can be something like that?  I will be driving the car next week to Nistune tuner to properly see what is wrong...
    • the Tomei LSD fluid with lsd kit. frustrated that it was shaking the car to crap and affecting everything else negatively, I pulled the diff last night, and removed the lsd carrier, could not find anything wrong, however it seem to be 100 locked up acceleration, and deacceleration, wondering if they sent me a 2 way not a 1.5??  either way I installed the stock open carrier back in place. test drove everything smooth as butter again. no shake, shutter, random, what felt like clutch slip and grab or drive shaft play, etc. something differently wrong in side the lsd. I might bother taking it apart (if possible) to figure out what's going on inside this carrier, as bought too long ago to return.  only draw back is its back to a one wheel wonder.
    • If there's oil in with the clutch, I hope it finds its way out even if that hole has a cover/grommet 😛 I don't want oil near my cars clutch! 😛 Interested to hear the answer about covering it, I'm assuming a bung for a gearbox from another car that has a grommet to suit.
