  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
no probs Rob ...... how you enjoying the new turbo buddie :D
Cam - nah im too nice to do that .... besides the way my life is going at the moment i think he's proven a point ..... even tho i hat eto admit it .... no one will love me like he does. But no didnt ansewer my phone on saturday anyway to find out what he wanted ..... again.
This week is my last week ..... yipppeeeeeee!! so happy but i did spend $250 on a Gameboy advance today ....... need an income to fund these things :) But it'll keep me amused on the way to SA
bam - i read you saying it somewhere... :D got pics.. but not here at the moment.. will post some when i get em...
lauren - you're not even in your mid 20s.. don't think that you can't find someone worthwhile.. thats just crazy...
As you may or may not have figured out the posting rules have been changed to 1 every 3 minutes.
This mainly due to a recent increase is useless and utter crap in some forums mainly the state whorethreads. The admin are decidin wheather to keep them or not. For those who want to complain, theres already an off-topic whoring section all to itself, also there is a Perth irc channel as well as a Victorian one.
So either prepare for this thread to dissappear and keep the other threads on topic or keep this thread going the way it has of late general day to day converation between a bunch of mates.
I have no problems with the direction of this thread, just be aware of the above and don't reduce it to the crap that has been happening elsewhere and it should be here to stay.
troy - understood.. why keep the history of this thread anyhows? why don't they delete it if they're having storage issues? fair enough opinions on the crap posting though...
bam - u whore.. :D should've seen some of the widebody m3 convertibles i found on the m1 out of london.. wiked cars.. would trade mine in a second... :)
lauren - look aorund.. there's quite a few people you could lean on i think you'll find...
Agreed on it taking out the "friendliness" factor.. i feel i've come to get to know quite a few of the people via this thread..
hi joel...
its not a storage issues its a content issue
with the vic and nsw clubs up and running and possible sponsors now reading the forums with more interest, some of the crap that goes on just isn't good for them as a club.
as i said earlier i see we have no problem with our whore thread as long as it stays the way it has been for the last few months.
we still need to work on some of the other threads in the WA section but thats no big issue as the off topic posts have been kept mainly to a minimum within the posts related to the relevant topic.
Cam I think i just want to get comfy now ..... sick of mind games, sick of a lot of things ..... just want something stable ..... something to come home too :D
My friends just seem to meddle. im growing tired of it .... no wonder andy always used to tell my mates to phuck off .... cos at the moment im feeling the same ...... mels mates have compeltely taken over my end of work celebrations ..... oh we are doing this and that ..... they havent even asked me what i want to do .... it shits me sooo much!!!
    • Well, this is probably where a wiring diagram and a multimeter come into play.
    • I can say to anyone thats doing this; having done a number of R clusters; just be careful if its an unknown cluster.  It takes a bit of force to pull up; but if it feels excessive then its probably stuck. I've had this and pulled the entire hair spring out; and I can tell you; its not easy getting the correct spring replacement with the correct inner diameter and winding. In my case someone had used some sort of adhesive to stick it to the spindle and it pulled the whole spindle out; which the force seperated the hairspring from the spindal and caused it to deform.  You may have to clean it (IPA); or in my case if i'd known i should have used some sort of solvent on it.  Also check out Cruizin Central on eBay. He does all sorts of dials; and you can email him with any custom designs you want. So if you want like certain logos etc...he'll send you a mock of what it will look like then you accept the order and he'll take care of the rest. Fantastic dials and he can do basically any design you want.
    • Have you confirmed its the actual axles? Also the wheel bearings that mount on the hubs to hold the axles wear out. I replaced mine as they got play in them. It sorted my play issue.
    • Ive converted a few clusters for the R33 with 320km/h dials. On the back there are some pads which can be bridged or unbridged (using solder or wick braid) to calibrate it. There is one bridge which is for MPH <> KPH; and there are combinations of bridges to offset it. There is probably a diagram  For example; this is my conversion for a 180km/h dial to a 320km/h dial (I put custom GT-R dials on it with the GTS25t layout) If you have J2 soldered (assuming the S clusters have a similar config to the R clusters); you may need to remove that solder
    • Back on topic 😉, these are some of the notable pages from the booklets that are supplied with each weekly parts update. I never knew the BNR32 test mule car had an S13 Silvia front end... *Edit: On closer inspection the test car still had the R32 body, but only the front end had Silvia panels etc.
