  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
Originally posted by Nizmo
i know i just want someone to lean on at the moment ..... noones there.
Hmmm , Cam's right.
There is a lot of people you can ask for some comfort. Depends on whether you want a friend or a lover tho...
You are only 20 and not displeasing to the eye so I would not worry and if you call Andy's protective , putdown style true love then I am a little worried about you.
Cheers
Ken
lauren so make your own plans and tell them its your party etc etc
bam we already do fall under that scrutiny and we can become a club when ever we want.
We have all the legal documents, I just have better things to put my money into atm, we want be getting cams affiliation in wa as its to much hassle and doesn't work with the way we would run are club and cruises etc.
Troy i always mean to donate considering how much i use the forums buts its something that you go - oh must do that - and gets put on the backburner for some reasonor another ..... will get my fat ass around to doing it one day tho.
Ken yeah but even Andys over protective ways can be a little more nicer than some other peoples dont give a phuck ways .... if you know what i mean :D yeha i know im only 20 but we all get a bit despondant and lonely sometimes.
ive been proactive enough in my time ..... a little too proactive .... ive done most of the stupid things and when i get like this im just likely to go back doing them again. Im ready to tell them to phuck off but it's just going to cause a whole load of shit between mel and me and i'll just end up with nobody to party with saturday night .... sit at home doing nothing like i did this saturday night :D
yes how did you go yesterday ken?
Hmm , might start charging money for rides. In the car that is ...:D
Got 4th o/r and 2nd 4wd behind Kevin Ledgers wrx racecar , a formula super vee and a track orientated westfield.
I was the first real roadcar and that's my excuse.
Niz , check your PM
Cheers
Ken
just been talking to micheal aka boxhead on MSN .... what did he do wrong ... hes not a bad bloke!
He might be alright but his constant refresh posts and arguing when someone queried the total uselessness of it all got very tiring.
His * if you don't like it **** off* attitude obviously pissed off enough people.
Cheers
Ken
Turbo's good lauren... just need to finish the project off and throw more money at it :D Really shows the need for a good ecu and some injectors and I think I need to get some really good brake fluid into the car now, the fluid makes a huge difference I am told, already got bendix ultimates on the front.
    • I’m not sure what happened I told them about sonic tunes free OTS tune and the next the I know .. I was booted..   To funny
    • Yea - I mean I've seen my fuel pump which is decades old and uh, while I'm not saying this with real knowledge... but I sure get the ick at using anything in the fuel system that produced the state of that pump. Many years ago I went through multiple pumps (and strainers) before I dropped the tank to clean it out with extreme violence. I'm talking the car would do maybe 50km before coming to a halt, which resulted in me cleaning out the filter with some brake cleaner and going on my way. None of my stuff ever looked like what came out of your fuel tank. I don't think I'd be happy with it unless every single component was replaced (or at least checked/cleaned/confirmed to be clean here).
    • I'm not going to recommend an EBC pad. I don't like them. Just about anything else would suit me better. I've been using Intima pads for a while now.
    • Agreed, and in particular the earth strap that should go from the subframe to the chassis but it often broken or left off. There is a section in the R32 workshop manual you can follow for troubleshooting if you don't see anything suspicious, and depending where you are (there is no location on your user profile) you should be able to get your hands on a second hand replacement unit still if needed
    • Yeah they mention as a R34 for 2.5 Turbo...but then again thos "small" were also for R34 by that different site. But i look into it and that 310mm EBC is for R34 GTT. And by those you linked the specs are the same 🙂    EDIT: I found these on one site here: DBA 4000 series T3 DBA42304S They are 310mm...and it says are for R34GTT...are there good? EDIT2: ok they have pads too.  What "color" should i get for street use? I dont want/need some noisy ones...(and if they are not that dusty that is good too)
