  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
Originally posted by Nizmo
i know i just want someone to lean on at the moment ..... noones there.
Hmmm , Cam's right.
There is a lot of people you can ask for some comfort. Depends on whether you want a friend or a lover tho...
You are only 20 and not displeasing to the eye so I would not worry and if you call Andy's protective , putdown style true love then I am a little worried about you.
Cheers
Ken
lauren so make your own plans and tell them its your party etc etc
bam we already do fall under that scrutiny and we can become a club when ever we want.
We have all the legal documents, I just have better things to put my money into atm, we want be getting cams affiliation in wa as its to much hassle and doesn't work with the way we would run are club and cruises etc.
Troy i always mean to donate considering how much i use the forums buts its something that you go - oh must do that - and gets put on the backburner for some reasonor another ..... will get my fat ass around to doing it one day tho.
Ken yeah but even Andys over protective ways can be a little more nicer than some other peoples dont give a phuck ways .... if you know what i mean :D yeha i know im only 20 but we all get a bit despondant and lonely sometimes.
ive been proactive enough in my time ..... a little too proactive .... ive done most of the stupid things and when i get like this im just likely to go back doing them again. Im ready to tell them to phuck off but it's just going to cause a whole load of shit between mel and me and i'll just end up with nobody to party with saturday night .... sit at home doing nothing like i did this saturday night :D
yes how did you go yesterday ken?
Hmm , might start charging money for rides. In the car that is ...:D
Got 4th o/r and 2nd 4wd behind Kevin Ledgers wrx racecar , a formula super vee and a track orientated westfield.
I was the first real roadcar and that's my excuse.
Niz , check your PM
Cheers
Ken
just been talking to micheal aka boxhead on MSN .... what did he do wrong ... hes not a bad bloke!
He might be alright but his constant refresh posts and arguing when someone queried the total uselessness of it all got very tiring.
His * if you don't like it **** off* attitude obviously pissed off enough people.
Cheers
Ken
Turbo's good lauren... just need to finish the project off and throw more money at it :D Really shows the need for a good ecu and some injectors and I think I need to get some really good brake fluid into the car now, the fluid makes a huge difference I am told, already got bendix ultimates on the front.
    • Hi,  Just joined the forum so I could share my "fix" of this problem. Might be of use to someone. Had the same hunting at idle issue on my V36 with VQ35HR engine after swapping the engine because the original one got overheated.  While changing the engine I made the mistake of cleaning the throttle bodies and tried all the tricks i could find to do a throttle relearn with no luck. Gave in and took it to a shop and they couldn't sort it. Then took it to my local Nissan dealership and they couldn't get it to idle properly. They said I'd need to replace the throttle bodies and the ecu probably costing more than the car is worth. So I had the idea of replacing the carbon I cleaned out with a thin layer of super glue and it's back to normal idle now. Bit rough but saved the car from the wreckers 🤣
    • After my last update, I went ahead with cleaning and restoring the entire fuel system. This included removing the tank and cleaning it with the Beyond Balistics solution, power washing it multiple times, drying it thoroughly, rinsing with IPA, drying again with heat gun and compressed air. Also, cleaning out the lines, fuel rail, and replacing the fuel pump with an OEM-style one. During the cleaning process, I replaced several hoses - including the breather hose on the fuel tank, which turned out to be the cause of the earlier fuel leak. This is what the old fuel filter looked like: Fuel tank before cleaning: Dirty Fuel Tank.mp4   Fuel tank after cleaning (some staining remains): Clean Fuel Tank.mp4 Both the OEM 270cc and new DeatschWerks 550cc injectors were cleaned professionally by a shop. Before reassembling everything, I tested the fuel flow by running the pump output into a container at the fuel filter location - flow looked good. I then fitted the new fuel filter and reassembled the rest of the system. Fuel Flow Test.mp4 Test 1 - 550cc injectors Ran the new fuel pump with its supplied diagonal strainer (different from OEM’s flat strainer) and my 550cc injectors using the same resized-injector map I had successfully used before. At first, it idled roughly and stalled when I applied throttle. Checked the spark plugs and found that they were fouled with carbon (likely from the earlier overly rich running when the injectors were clogged). After cleaning the plugs, the car started fine. However, it would only idle for 30–60 seconds before stalling, and while driving it would feel like a “fuel cut” after a few seconds - though it wouldn’t fully stall. Test 2 – Strainer swap Suspecting the diagonal strainer might not be reaching the tank bottom, I swapped it for the original flat strainer and filled the tank with ~45L of fuel. The issue persisted exactly the same. Test 3 – OEM injectors To eliminate tuning variables, I reinstalled the OEM 270cc injectors and reverted to the original map. Cleaned the spark plugs again just in-case. The stalling and “fuel cut” still remained.   At this stage, I suspect an intermittent power or connection fault at the fuel pump hanger, caused during the cleaning process. This has led me to look into getting Frenchy’s fuel hanger and replacing the unit entirely. TL;DR: Cleaned and restored the fuel system (tank, lines, rail, pump). Tested 550cc injectors with the same resized-injector map as before, but the car stalls at idle and experiences what feels like “fuel cut” after a few seconds of driving. Swapped back to OEM injectors with original map to rule out tuning, but the issue persists. Now suspecting an intermittent power or connection fault at the fuel pump hanger, possibly cause by the cleaning process.
