  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
Originally posted by Nizmo
i know i just want someone to lean on at the moment ..... noones there.
Hmmm , Cam's right.
There is a lot of people you can ask for some comfort. Depends on whether you want a friend or a lover tho...
You are only 20 and not displeasing to the eye so I would not worry and if you call Andy's protective , putdown style true love then I am a little worried about you.
Cheers
Ken
lauren so make your own plans and tell them its your party etc etc
bam we already do fall under that scrutiny and we can become a club when ever we want.
We have all the legal documents, I just have better things to put my money into atm, we want be getting cams affiliation in wa as its to much hassle and doesn't work with the way we would run are club and cruises etc.
Troy i always mean to donate considering how much i use the forums buts its something that you go - oh must do that - and gets put on the backburner for some reasonor another ..... will get my fat ass around to doing it one day tho.
Ken yeah but even Andys over protective ways can be a little more nicer than some other peoples dont give a phuck ways .... if you know what i mean :D yeha i know im only 20 but we all get a bit despondant and lonely sometimes.
ive been proactive enough in my time ..... a little too proactive .... ive done most of the stupid things and when i get like this im just likely to go back doing them again. Im ready to tell them to phuck off but it's just going to cause a whole load of shit between mel and me and i'll just end up with nobody to party with saturday night .... sit at home doing nothing like i did this saturday night :D
yes how did you go yesterday ken?
Hmm , might start charging money for rides. In the car that is ...:D
Got 4th o/r and 2nd 4wd behind Kevin Ledgers wrx racecar , a formula super vee and a track orientated westfield.
I was the first real roadcar and that's my excuse.
Niz , check your PM
Cheers
Ken
just been talking to micheal aka boxhead on MSN .... what did he do wrong ... hes not a bad bloke!
He might be alright but his constant refresh posts and arguing when someone queried the total uselessness of it all got very tiring.
His * if you don't like it **** off* attitude obviously pissed off enough people.
Cheers
Ken
Turbo's good lauren... just need to finish the project off and throw more money at it :D Really shows the need for a good ecu and some injectors and I think I need to get some really good brake fluid into the car now, the fluid makes a huge difference I am told, already got bendix ultimates on the front.
    • Yes, I had ordered the spherical bushings at the same time as the rest. I have high hopes for the anti squat reduction kit.
    • Make sure you use the spherical bushes** on the lower arms, ifyou do that. ** at least, if not the whole replacement lower arm.
    • The tap for coolant flow control will be stuck open. It's not just the air door motor that dies.
    • Not really, but the heater box is pretty simple mechanically....if the door is one way the air bypasses the heater core and if it is the other way it goes through it for warm air.  If you are sure the actuator you moved manually is for the heater mix (there would also be one for output air direction) then I'd take the heater box out and see what is happening (you'll have to regass and re-coolant the systems afterwards) BTW pp724 onwards from the GTR workshop manual cover the system in good detail, it is probably worth checking. I think the IAT sensor might be a problem electrically for getting cold (if you got 24 error code not -24 it thinks the incoming air is -50c) and it covers how to test the sensor (although most likely it is either not plugged in or a wire is damaged)
    • Use the GKTech subframe bush and bring your subframe 10mm closer to the chassis. You'll need to fix an exhaust hanger to suit. One of the best mods I've done.
