  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
haha well the other side was rusty - and if my brakes got that good-a workout they wouldnt be rusty :cheers:
least now everyone realises im not a whinging female and their was really something wrong!! ..... and at least Cam did my rear and not my front!!
ones been snapped for a while Richie .... but it satin such a way on the caliper that it didnt leak - when they changed my pads yesterday they saw it .... its bent and snapped ... and just disintergrated when they took caliper off.
Other one is rusty and probably pay me to get that replaced as well.
And my disc were so badly in need of machining that theeir machine was "heavy duty" enough for the job so they had to take them to someone else.
that sounds like my old front brakes, they were getting really spongy and when i pulled off the wheels to get the suspension off we found that the caliper centre seals were gone on both sides.. that and the discs looked like they had ridges in them!
My brakes are good now but they shudder when they get hot cause they werent bled properly when they were changed.
yes the place said i was a very lucky girl!!!!
thats why on the country cruises i didnt push it as much because i knew something wasnt right with the brakes!
hmmm have to make sure im alright for cruise Sunday then - cos i will have New n Improved brakes to test :cheers:
well it'll give me the confidence to shove my foot on the accelarator more cos now at least i know i can stop!!
yeah got to iron out this roughness in my car .... i was listening to it when they started it up at brake place and yeah its sounding a bit like an old jallopy!
gotta get price on Redline Gearbox oil today for paulie - all 18Litres of it. Oh and i was at the brake place looking thru a holden mag .... thats all they had honest .... and there was a picture of my mechanic 'ironing' out some problems on some featured guys car ....... bloody trev he is!
haha i cant believe that you let a Trev do all the work!
I have to change my gearbox oil too, mines getting a little crunchy, i dont think that is has ever been changed.
My mate is getting some stuff though where he works.
I have still got a couple of thoudans kms till my next service, luckily...
    • I certainly fall into the annoyed camp, but glad to hear that if it's happening at low boost then I'm not likely going to blow a turbo and end up with metal shards in my oil. Just feels like it prevents me from really driving it without hesitation and "peak" performance. Wonder if it's the VCAM, it did an impressive job of shifting the torque curve and faster spool, but maybe now it's "too fast" and there's too much air for how open the throttle is.  Based on some other threads, will also do some reading on synchronizing the actuators. They are the default actuators that come on the Garrett's and I would think they would be set the same coming from the factory, but if the turbos don't actually work exactly the same way at the same time as previously mentioned, it would be worth making sure the actuators are actuating together properly
    • I went down this rabbit hole before, ended up sourcing a motor from the UK (I'm in Japan) which also didn't function correctly. With the original motor, I disassembled it and reassembled it and it works somewhat, sometimes. What I could deduce from all my screwing around is that there is calibration of the gears on the inside of the motor and two ramps on the main gear which activate switches that operate the motor and move the sunroof either to retract into the roof or tilt. Where I got stuck was that, it seemed in my case that one or both of the switches that are activated by the ramp on the gear did not always activate and thus the motor did not move, causing it to sometimes not retract or tilt (apologies, I've forgotten which way it didn't work.).  Of course this part is discontinued at Nissan now, it's the same part in the S15 but no other models. I also contacted the manufacturer of the component for schematics - forgot the name, they're based in Gifu - but they declined to share the information due to being bound by an NDA, sadly. Looking through my pictures now, it seems I last had a crack at this in 2022. See, I so kindly wrote "open" and "close" next to the switches. If you figure it out, please do tell me. Those little switches, with the red buttons may need to be replaced.
    • It says 300ZX, does that make it an Aus delivered car? Funny how back in the day I just couldn't care less about Z32's and these days I am just in love with them. Back when Nissan was into pushing the envelope. 🤣
    • Hi guys, just after some guidance with an R34 sunroof that has stopped working correctly. It still opens and closes perfectly fine, but it no longer tilts/vents up or down. As a result, the rear of the glass now sags a bit as it drops down slightly in order to retract into the roof, but now it can't pop upwards into a flush position. I’ve probed the pins on the back of the switch connector with a multimeter and it seems like both switches (for open/close and tilt/vent) still work correctly. Any ideas on what it could be, or where I should even start in terms of diagnosing? I'm sure someone's had this issue before but I haven't been able to find anything online relating to this specific issue, most of the issues are with the seals leaking or the motor failing entirely. Thanks in advance!
