  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
lauren - its through a firm that arranges the teachers for the uni's and stuff in Singas. The head of IT at murdoch set it up for me. I want to use it more as a means to get my name known - I'm not too fussed about work, the unemployment rate is very high in singas at the mo and they are trying to cut down on giving jobs to overseas ppl.
apparently been busted for a little while they said by looking at them .... i went there for a brake pad change and a machine cos they were vibrating so badly!! .... actually so badly they had to get them machined off premises cos theirs wasnt heavy duty enough to handle job haha
bwahahahahah
nice work..
i gotta get my bum in gear and start putting my bunky back together which means putting the big big brakes on again, im tempted to just wait till a decent gearbox option is affordable, and putting some 6 pots on the front and the alcons on the rear, ahh money its so nice to have it.. and then spend it..
haha Denver .... what you doing to that poor car ... why i wont come play motorsport with ya .... turns ya cars into bunkies!! :)
it had the lot Liz: Sex, Dicks and size, midgets, orgies haha you wouldve been impressed :D
    • Yes, I had ordered the spherical bushings at the same time as the rest. I have high hopes for the anti squat reduction kit.
    • Make sure you use the spherical bushes** on the lower arms, ifyou do that. ** at least, if not the whole replacement lower arm.
    • The tap for coolant flow control will be stuck open. It's not just the air door motor that dies.
    • Not really, but the heater box is pretty simple mechanically....if the door is one way the air bypasses the heater core and if it is the other way it goes through it for warm air.  If you are sure the actuator you moved manually is for the heater mix (there would also be one for output air direction) then I'd take the heater box out and see what is happening (you'll have to regass and re-coolant the systems afterwards) BTW pp724 onwards from the GTR workshop manual cover the system in good detail, it is probably worth checking. I think the IAT sensor might be a problem electrically for getting cold (if you got 24 error code not -24 it thinks the incoming air is -50c) and it covers how to test the sensor (although most likely it is either not plugged in or a wire is damaged)
