  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
quote from the magazine on peelies
"I know you guys cant help but turn to gooey shit each time a girl spreads her lips for you. I know my old boyfriend would almost chuck a thrombo when I greeted him in this very position when he came home from work. I also don't understand chicks that wont do peelies for thier guys. Whats wrong with you? Don't you know the guys get off on that? Sheesh!"
hahahahaa
haha denver come back.
I think no n00bs use whoretown cos they come in see what the hell ive bee talking about and leave straight away with these people are sickos running thru their minds!
yeah our benders are so much fun ..... gotta add a few more people to my dirty sms list :)
haha always knew you were sad Denver .... well thats what paul keeps telling me anyway *jk*.... u would be pleased to know i stick up for you :)
ok we'll take my phone next time .... but ive got way too many numbers in there haha! i could get into a LOT of trubble!! Stalk him next time Liz :)
