  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
haha nice to have you whoring for once kymbo.
you got a cruisy day?
most female bosses ive had are either suspiously lesbo looking and more man than women or sex crazed old girls tha tlike to regale every detail of their weekends exploits.
Never had a good looking male boss.
you'd give me my own way Kym *batts eyelids* ;)
trust me i know more about computers than more dorks i have ever worked with. Besides telling a person to switch off the computer and switch it back on when something goes wrong and downloading drift clips all day like our IT guys do is hardly rocket science.
haha Train - i caught one of those this week when my car was outta commission ..... what a cultural experience that was!! how many freaks they can cram into a tiny space is amazing ..... i even think i saw boy george :)
Maybe..... but it'd cost ya baked goods, chocolate, or coke :)
heheh, IT guys downloading stuff.. sounds like me 6months ago... before they said "here kym, you can now be a programmer, do this!"
