  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
I took the volvo out last nite to go to the shops and as bad luck would have it my secondaries (the big barrels on the carb) decided to clog up just before a white R33 tried to have a go with me. I might as well have raced a datsun 120Y I still would have lost, the car was coughing and spluttering so much. Up till then that evening it was running mint.
I'll have to wait to fix the secondaries as the wife doesn't want me taking the car off the road for a while.
Cam,
the secondaries are probably clogged, I recently rebuilt the carb with a kit and sometimes little bits of casket sealant can fall into the needle holes, should be easy to clean. The other problem is the vacume diaphram opener is stuffed so you have to 'feed' the throttle or it bogs down (not a big problem for me tho').
BOV wise , I can call past after work on the way home or this evening after dinner?
    • Ok thanks..that was my second question if i can somehow bypass this even with Nistune(that is all i have right now...aparat from stock ECU. So with some aftemarket it can by "bypassed" or make it work?  I know there is Link or Haltech (mainly used). We have ECUmaster here so i will gather some info about it.
    • Yes. You will need to get the original boost sensor and wire it in. That is.... if you plan to use a stock ECU - even a Nistuned ECU. The Nissan ECU will not operate correctly without it connected. And yes, it will do annoying stuff like you are experiencing. You will almost certainly be better off with some aftermarket ECU, than trying to hunt down rare sensors.
    • Ok so ABS/TCS is "not" the problem. Yeah i know now about the ABS with Nistune(i told that to the Nistune guy) but iam not 100% why or why i dont have ABS. ABS cube is in the engine (always has been) but i had braked couple of times rly hard and brakes just locked and scream. Does all Skylines have ABS cube? That boost sensor https://www.sau.com.au/forums/topic/367633-wtb-r34-gtt-turbo-pressure-sensor-pics-inside/ Is this it? I need to ask but i have a picture of engine bay and i do not see that (100% is not in that place) If i do not have this the car can do what mine is?(cutting around 4000 rpm) Here is the pic of my engine bay(only one i have) BUT i think i dont have that cuz loom was used from my RB20DE NEO and i know (obviously) that it does not have boost control or any wire to that...) so maybe that is the problem? (i dont know for 100% if that car where the engine is from had that)...but i dont have the loom from that
