  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
ok just came back from little drive from beach...
damm saw frekin more skylines on the raod then WRX... lol
and some dumm Black R32 GTST I think or could be GTR... dump it on 2nd and made massive two 5m black line infront of UWA intersection... lol
I hope it wasnt some1 I already know... dumm ass.
hey aidwin - awwwwww how come everytime i go its mediocre so i decided to stay home and it turned out good :(
Hey Shaggs, too lazy today - had enough adventures for one weekend
Nice to see you back Russ.
got a 4 point speeding fine last night
excellent
didnt even realise the speed, switched from 80km zone to 70km zone was 16 km over then all of a sudden became 26km over
BUGGA
ah well
it was all in good spirits cos i really didnt realise
anyways both cars up for sale very shortly
gonna buy a bicycle
or a motor cycle *eh eh Cam*
got 2 points left now
thats worse than Niz
cant ride a motorcycle in the wet Riaz .... well ya can but at your own risk :( haha worse than me .....better than paul :)
Got my hair chopped off ........ ahhh low maintenance (its just below my ears ..... should be back down to my shoulders by the time for autosalon tho .... and it'll be a lot more healthier than it was :)
    • That looks good, but I think you're going to need much beefier side skirts now.
    • They are daft and there's a reason it never caught on. Steering feel? We don't need no stinking steering feel!
    • I gotta pull you up on this. It's driving me crazy. A shutter is something that closes, like over a window or in a cmera. The word you want is shudder. That LSD is clearly f**ked. Take it to a diff shop and get it disassembled and examined by an expert. YOu might have plates welded together or something equally crazy.
    • Define "starting to fail". Wy not just rebuild them?
    • Check the Nistune doco. There are a few assumptions being made here that might not be valid. I will list the things that occur to me: Base map. Base map for what? Base map for Z32? Then the cranking pulse width is probably wrong for an RB25. The extra 500cc of capacity might well be enough to prevent it from catching. Base map for RB25? I don't think you can load one of those into a Z32. You have to just make the settings correct for an RB25 in the Z32 base map. That is either K or the TIM to get the pulsewidth right. Loom. You bought a loom for an RB. And you plugged it into a Z32 ECU. Did you make sure that any iwre differences were swapped. From memory, there's at least a couple. And as per the others, I would suggest making sure that the fuel pressure is correct while cranking and that the injectors are actually flowing as expected. They really must come out and go on the bench, unless you do find that you have messed up as per above points. I would also suggest watching in Nistune to make sure that everything is reading correctly. That the correct binary flags are raised at the right time (like the crank signal), that there's no stupid values in K or TIM. That you have not got mismatched firmware for the ECU and/or a wrong image loaded.
