  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
haha Aidwin i wasnt invited anyway - but thats cool i made some really yummy pasties ..... chicken, bacon, brie cheese, taste cheese, spinch and packet of cream of chicken soup (jus tthe powder) :) turned out pretty yummy :(
So ken that doesnt ansewer my question .....unless you can drift the washing machine :)
Speaking of drifting...
Put the R in 2wd at the end of Sundays MC day and had a bit of fun.
Go here
http://files.franzonline.net/images/2003-0...4-MCMotorsport/
And here
http://www.car-porn.com/gate.html?name=Gal...bnails&album=75
Damn those rears don't last long:D
Cheers
Ken
Originally posted by Nizmo
so will it be gone before adelaide :)
Very likely but have no fear.
We are going anyway . May have to buy something 2wd for a while .
Might look at Riaz's 200sx or Jash Cefiro drift pig.
Cheers
Ken
whos white R34?
Barbara Dellow.
An older lady who punts it bloody well. Is auto and does the MC series and Maxaction.
Was pretty slow when she started but set some good times yesterday.
Cheers
Ken
Originally posted by gtrken
Barbara Dellow.
Cheers
Ken
Respekt :uh-huh:
