yeah, but rims are a bit different. they have weight and aesthetic influence and are more a matter for contention.
the exhaust takes the hot shit from the front to the back, and provided it makes the car go faster, WGAF which boffin made it?
besides - for something like the REX, theyve probably done more developent here than in JapLand anyways. AUS rexxes are a shitload faster than those in Japan.
  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
