  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
I believe R32's are quite a bit harder to find at the moment than the 33's..... You really want to have some idea in your mind about what you are looking for ( either 32/33 , manual/auto , turbo/non turbo, colour? , modded/stock , cheap(maybe needs a bit of work?) or one that may cost a bit more but is in better condition )and then start to have a browse around and just see whats out there..... plus there are a couple of guys on here looking to get rid of there skylines too dont forget :P
Originally posted by MrGTST
I believe R32's are quite a bit harder to find at the moment than the 33's..... You really want to have some idea in your mind about what you are looking for ( either 32/33 , manual/auto , turbo/non turbo, colour? , modded/stock , cheap(maybe needs a bit of work?) or one that may cost a bit more but is in better condition )and then start to have a browse around and just see whats out there..... plus there are a couple of guys on here looking to get rid of there skylines too dont forget :(
cheers for the help....
well im defianetly after a manual and a turbo(why buy a nonturbo) :P
colour aint really an issue
mods ain't to much of an issue as long as of got a good base to work from.....
got up to $20G to spend
Hi Niz ;)
yeah you would reckon that with almost 300 Hp at the wheels I could get into the 13's, pity I cant. I could probably whack on the bigger turbo like paul be running 350+ at the wheels and still tun that damn 14.1 :(
Well thats a good start ReVN211... thats basically what I did.... knew I wanted a manual turbo R33 with a GTR rear wing with no GTR badging.... had a look around the importers and found one in really good condition with everything I wanted, and it appears more recently it came with even more I didnt know about :)
    • I refer you to this thread on PF, by someone who knows what he's doing. Paints a good picture of the humble AD09.
    • Ha, I've never pressed the X in all these years incase it removed the notification for all Admins
    • I don't know, I've never done it that way, but 1. While it is an interference engine, there is still clearance between the valves and the piston at all points in the regular timing cycle 2. There is not a lot of distance before you can't catch the top of the valve stem any more I don't know if 2 is greater or less than 1. But 3. If it doesn't work out you are f**ked, engine is coming out to disassemble so it is a big bet.
    • Semi slicks are horrible for road use, just use a high performance road tyre unless you really need the maximum grip. Noisy, unpredictable (amazing, until they are not), expensive due to very high wear and not good in cold and particular wet. And yes, it is a thing to store cars on stands instead of tyres if you know they are going to be parked up long term.....but who ever realises that a short park is going to stretch into years before it is out again!
    • I know in Australia you'll definitely get above 30c. Parked in the shade in Summer you'll be above that. 😛 But in cooler climates, you might get that warm driving on the highway for a bit, but you'd never get to full heat temp. I'll try and find some of my historical tyre temps between Aus summer and winter (be aware immin the warmer area of Aus too.)
