  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
I believe R32's are quite a bit harder to find at the moment than the 33's..... You really want to have some idea in your mind about what you are looking for ( either 32/33 , manual/auto , turbo/non turbo, colour? , modded/stock , cheap(maybe needs a bit of work?) or one that may cost a bit more but is in better condition )and then start to have a browse around and just see whats out there..... plus there are a couple of guys on here looking to get rid of there skylines too dont forget :P
Originally posted by MrGTST
I believe R32's are quite a bit harder to find at the moment than the 33's..... You really want to have some idea in your mind about what you are looking for ( either 32/33 , manual/auto , turbo/non turbo, colour? , modded/stock , cheap(maybe needs a bit of work?) or one that may cost a bit more but is in better condition )and then start to have a browse around and just see whats out there..... plus there are a couple of guys on here looking to get rid of there skylines too dont forget :(
cheers for the help....
well im defianetly after a manual and a turbo(why buy a nonturbo) :P
colour aint really an issue
mods ain't to much of an issue as long as of got a good base to work from.....
got up to $20G to spend
Hi Niz ;)
yeah you would reckon that with almost 300 Hp at the wheels I could get into the 13's, pity I cant. I could probably whack on the bigger turbo like paul be running 350+ at the wheels and still tun that damn 14.1 :(
Well thats a good start ReVN211... thats basically what I did.... knew I wanted a manual turbo R33 with a GTR rear wing with no GTR badging.... had a look around the importers and found one in really good condition with everything I wanted, and it appears more recently it came with even more I didnt know about :)
    • So either way it is gearbox out and look what is wrong?  I know about the input shaft bearing. Even before swap/new clutch the it sounded exactly like this: So is that inout shaft bearing or the other was installed backwards?  And can some please tell me the part number for that input shaft bearing? The gearbox is small box from R34 N/A and number is FS5W71C. Thank you
    • I am yet to see anyone ever regret a quaife or helical. ...other than drifting/skidpan duties. I kind of want to upgrade my factory helical with a Quaife (but really it's not ultimately that different, and is a MASSIVE UNDERTAKING), that's how good the hype is about them, that I want to try them 'just to see'
    • D2 and Ksport are essentially the same thing and basically just generic Taiwanese manufacture. Better than ChinaBay crap, but... not top shelf. Öhlins have got to be some of the best dampers around, so likely to be a good option. It's going to get to the point though where I suggest you buy from Oz. We have at least 2x excellent options here. If I were you though, I'd be talking to KW about doing something for the R33. There's bugger all difference between that and the 32. In GTR land, anyway.
    • KW only offers a set for the R32 GTR. Popular options are D2 racing, Ksport or Öhlins. I have a D2 Racing coilover set, though I don't know for sure which one.
    • Well, the good news is you have more than one very good option for new coilovers in and around your country. Worth the drive over to KW to talk about GTR stuff.
