  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
boo!!
haha got a meeting between some of the ladies that work here and the director general on friday regardinng our workloads and some constructive comments blah blah blah - thing is - i leave on ejob to start a new job when i come back .... ive moved around this friggin place 4 times now ..... i have no constructive comments about my workload cos it varies ....... i think the problem is his internet bill is still to high so he's going to find the source of the problem i.e me ...... but im a temp and the policy says we can use it as long as it doesnt interfere with work which it doesnt - i get all my work done before time.
CaminPerth: I think I musta missed something with the Driftin thread...it was there last night?
Someone start a " i'm better than you at drifting" debate or something?
Anyway I did get the links to the pic's :D
http://files.franzonline.net/images/2003-0...atMCMotorsport/
6 points is huge .... haha but the coppers i got were a little better than that .... they let me off the WHOLE fine ...said they had better things to do :D - for once some police with their priorites straight!
    • UPDATE: Yes the GSP Axles are compatible. I installed it on my R34 today and they are working a treat! Turns out that the S13, S14, S15, and 200 SX all used the same axles as the HR34, and ER34 NA models. Which is 2 bolt x 3 pairs.
    • Also build this EH ute with 370z motor and gearbox with a couple of turbos just for fun.
    • Got the passenger door on plus the master cylinder and booster. Loaded up to take it home. At home, the colour changes a lot in the light.
    • Nothing cheap, but I have seen the AC Hydraulic DK13HLQ which is pretty close to what you're asking for. The problem is the hydraulic cylinder mandates that the back of the jack be a certain height and Skylines have fairly deep inset floor jack points. A more certain and cheap option is to get some nominal 2x10 inch lumber boards and have one board be 1.5 feet, the other board 3 feet. Glue it all together with lots of clamps to maintain pressure. Make two of these. The ramp suggested above is a good idea, it takes quite a bit of clutch slip to get over each of the boards. I only need the first ~1.5 inches for my low profile jack on a standard ride height car but a lowered car you want to go up to the full ~3-3.5 inches. Paint it or store indoors if you want it to last.
    • Ok. And Nistune? I read (here too) mainly on Stagea threads that it can by "turn off" with Nistune. But they say they still had the sensor plug in. Next week iam going to the Nistune(and other ECUs) tuner so i can finally make it work. I drove the car home and apart from the cut it drove great. No misfire no smoke no hesitation or rough start...so hoping it is this sensor that is missing
