  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
anyone whose driftin by scarbs later trying to orgnisea mini cruise around perth, weill be at scarbs from 9 - 10ish tonight top carpark 0413559406 mob if anyone interested so far got
2x skyline (stock as rocks)
1x rex
1x done up mirage .. and what ever else we can pick up
mark
Yeah its hard to tell its me... I look so stock :D Cant wait to pack 370hp instead of 320hp :( btw: I know of someone running the td06-25g and making a reasonable bit over 300kw @ rear wheels on stock internals, not sure how long they have been running this for and not sure how much longer its going to last.
