  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
not bad man, long time no see :(
shit all been happening just been working heaps and fixing my car etc :) hahaa hoes man thats what a black mans life is all about lol :) (legal notice: to my girlfriend, anything said above is irrelevant if you read it, don't believe it) ehehehehehe :)
cam i am part of the *****less car club heheh flamage here i come :D
adrian :P
