  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
nah it could be a "thing" i get occasionally ..... i havent had it in a while tho .... last time i got it - it unfortunately hit me in pauls car - he was lucky i managed to keep control of my stomach ..... and it wasnt motion sickness or anything.
Its just ever since i was 11 i just get these waves of nausea ... sometimes it lasts 24hours .... longest its lasted was 2 weeks where i didnt eat cos i couldnt and therefore got so weak that i would just fall to the floor everytime i got out of bed .... i lost 10kgs and my ribs were just popping out everywhere .... my parents thought i had an eating disorder it was bloody scary. But i still get it occasionally never as bad as that tho ... still worries my love ones but its nothing i have control of and my mum has something similar.
nah .... i dun like doctors .... only go to them when its fatal - which ive only made one trip to the emergency room my whole life..... and plan to make it the only trip!!
Actually a girl i work with had a similar thing .... she got hospitalised for it .... got fed thru an intravenous drip - no explanation for it
well hate to love u n leave ya but i originally got on here for a bit of a look around ..... andnow im off to curl up on the couch n watch TV.
Its sad i couldve gone out tonight but chose the couch instead .... im getting old .... feeling sick doesnt help either :P
Take care :grouphug:
    • Have you confirmed its the actual axles? Also the wheel bearings that mount on the hubs to hold the axles wear out. I replaced mine as they got play in them. It sorted my play issue.
    • Ive converted a few clusters for the R33 with 320km/h dials. On the back there are some pads which can be bridged or unbridged (using solder or wick braid) to calibrate it. There is one bridge which is for MPH <> KPH; and there are combinations of bridges to offset it. There is probably a diagram  For example; this is my conversion for a 180km/h dial to a 320km/h dial (I put custom GT-R dials on it with the GTS25t layout) If you have J2 soldered (assuming the S clusters have a similar config to the R clusters); you may need to remove that solder
    • Back on topic 😉, these are some of the notable pages from the booklets that are supplied with each weekly parts update. I never knew the BNR32 test mule car had an S13 Silvia body...
    • This. A 3d wheel alignment is like $120...just take it to the shop. Since theres probably multiple adjustments that need to be made after changing something. Mine has front/rear lower arms, traction rods, tension rods, camber arms, toe arms, front upper arms, hicas kit, sway bars and coilovers. I measure from the edge of the bolt holes on the originals and set the same length on all the adjustable stuff to dial it as close as I could to OEM. Took it straight for alignment; it didnt feel right at all...after alignment, it feels perfect. Similarly i've just changed the springs on another car; and I still needed multiple adjustments to bring it back in spec.
    • A full Veilside kitted JZA80 Supra in Meriken park in Kobe city a few weeks back
