  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
:D paul .... do what i do - ignore them ..... i still get calls on my phone from my temp agency ..... ive told them a million times whats going on .... i aint returning their calls to repeat it again!!
My lips are all dry n cracked - it hurty and yukky!
missing....where did they go? :D
my car is missing an intercooler .... 3.5 Zorst .... EBC ..... :D
nah not paying me too much .... well they are saying they hadnt paid me when they had ..... its really weird .... but yeah i just got paid weally early when i thought i got paid too much.
mmmm company car :drooling: ..... thats what i want ..... and petrol card ..... if i get this new job its part of the package ..... i would have all those above goodies on my R33 in no time!!
yeah but you also have to pay FBT on company cars .... so really you still have to pay for them but you dont have to worry about licensing and insurance at least.
today is going rather slow ..... maybe a sign of things to come!
