  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
Soarer yuk - one tried to take me on on the way home :)
Car dealership in Cannington .... Personal Assistant/ Marketing ..... Salary+incentatives+car+petrol :)
Dont mean to sound egotistical but if theyve given me an interview ive got it ..... only thing i thought obstructing me was my age but obviously that aint an issue and ive been PA to John Hughes and i can do absolutely everything in a car dealership .... so now ive big noted myself i probably wont get it but anyway im pretty confident
night cam :wavey:
yeah debt is a horrible horrible thing ..... my parents are all like "ooooh aarons buying a house (guy next door same age as me .... we were born in same hospital at same time our mums went to school together)" and they did this whole "save n buy a house pressure thing" ..... and i basically told them "phuck that i dont want the responsiblity, i have no interest in houses i would rather pis money away on my car" ....... which made dad get all shitty but hey - he'll build a bridge and get over it.
Originally posted by Sneeza
night cam - get better babe (ginger is the answer - OR by echanacia tablets from the chemist, they will work)
^ Born mother :uh-huh:
Why dont you sell house .... pay off mortgage ..... split it with Drew .... take your half - go on world trip!
    • Yes, I had ordered the spherical bushings at the same time as the rest. I have high hopes for the anti squat reduction kit.
    • Make sure you use the spherical bushes** on the lower arms, ifyou do that. ** at least, if not the whole replacement lower arm.
    • The tap for coolant flow control will be stuck open. It's not just the air door motor that dies.
    • Not really, but the heater box is pretty simple mechanically....if the door is one way the air bypasses the heater core and if it is the other way it goes through it for warm air.  If you are sure the actuator you moved manually is for the heater mix (there would also be one for output air direction) then I'd take the heater box out and see what is happening (you'll have to regass and re-coolant the systems afterwards) BTW pp724 onwards from the GTR workshop manual cover the system in good detail, it is probably worth checking. I think the IAT sensor might be a problem electrically for getting cold (if you got 24 error code not -24 it thinks the incoming air is -50c) and it covers how to test the sensor (although most likely it is either not plugged in or a wire is damaged)
