  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
Originally posted by GTS-t VSPEC
Bam, Haha, that's what she thinks, let her believe what she wants:D
Bloody denial :uh-huh:
i usually keep a camera in my car too :) next time i'll take a picture ..... then you'll have explaining to do :)
Hi Pauly and Ken,
I was an offical for the Classic rally and had the white GTR doing its thing. I was time keeping for a couple of stages. I did notice that C-RED and 3 cars in 2 x S15, 1 x S13. There was even a maroon GTS-T (Yeah) in there and a ALL girly team driving a S13. Some other very nice cars as well, cept Trev Tader in the Monarow.
PS All the DAN's are back online yeah
:ak47:
    • I would just put EBC back on the "I would not use their stuff" pile and move on.
    • Can I suggest you try EBC directly again and link them to as many competitor catalogues as you can to show their listing is incorrect, eg https://dba.com.au/product/front-4000-series-hd-brake-rotor-dba42304/ If you have access to an R33 GTST VIN and your VIN, you could also use a Nissan Parts lookup like Amayama to show them the part number is different between 33 GTST and 34 GTT which may get their attention
    • So i got reply from EBC and they just this site where you can clearly see those 296mm fronts on R34 GTT. I send them photos and "quotes" that 296mm are not for 34 GTT and they are too small. But it will be very hard to return them cuz nobody here knows 100% and they just copy those EBC catalogue :-D https://ebcbrakesdirect.com/automotive/nissan/skyline-r34
