Originally posted by XRW
there not allowed to
bottled water is meant to remain exactly that, bottled, lid and all..
its against the health act for them to sell it to you with no lid and opened.. as it possible its been tampered with..
if they give no lid demand it..
they can take the lid off in front of you and give it to you. same principle applies to beer.
  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
never been a big "smoker" the only effect i get on it apart from feeling extremely dumb is extremely horny ..... which aint such a bad thing :D
i leave work 3:45 get home 4:30 a go :(
Cams to go in wasnt it?
yeah thats the thing with Skylines take the normal cost for a non-import .... double it tripple it and there you go!!
As soon as you ring anyone for advice or parts enquiry you get "Oh because its an import blah blah blah going to cost more" I swear they see dollar signs in their eyes!
yeah my cams buggered and i think i have stuffed a few valves...
but won't know until i take it apart.
works out good in a way as i will be respraying my engine pay, chroming numerous engine bay parts so will look all nice a pretty once i get a few other problems resolved on the market she goes :D
yeah would liek to give my engine bay a clean up ..... just i know that once i start pulling things apart i wont be able to get them back together :D
And my dad doesnt have too many tools either soooo i'll just leave it with sand all in it. LOL there was this massive storm one day .... and i got caught driving thru it ... anyway i was at a set of lights and there was a construction lot next door and the wind picked up all the sand from the yard and dumped it all over my car ..... and now ive got yellow sand in the engine bay .... as someone said .... it looks like a bloody beach in there!!
    • A bit late but A disk S13P fit over stock R32 GTR brakes, usually A disk front, O disk rear works.
    • Or, the height of the release bearing is not correct for your combo. Start with the bleeding and checking the slave moves throughout its range when you press the pedal (2 person required), but it is possible for the height to be internally wrong too (box back off to measure.
    • Yes, there's quite a few things that can go wrong during a clutch install. Very unlikely. I have a similar clutch. They (ACS) make good gear. No, it is not normal. It is possible that you just need to bleed the clutch slave. But the new clutch will also have a more aggressive actuation force/pressure, and so your old slave cylinder might be a bit leaky or otherwise compromised, and not up to the extra force required. Or the master cylinder, same.
    • Hi...so a "development" here aswell The swap is "done" and car went "test drive" BUT it seems the clutch(maybe gearbox?) is a little bit sad? I bought this clutch kit https://justjap.com/products/xtreme-heavy-duty-organic-clutch-flywheel-kit-nissan-skyline-r31-r32-r33-push-type "Problem" is that the first gear is hard to put into and it seems that the clutch is not disengaged. It was not the problem with the old clutch...(or like sometime the first gear would not get as easy specialy when the fluid was cold) So? Can it be like...bad "install" or is the clutch wrong ((it should not have been) i done research to get the right one) Or is this "normal" with new clutch and needs to be break in?
    • @Duncan I can try  and thanks i did not thought about VIN and part numbers for 33/34. @GTSBoy yeah it looks like iam gonna do that
