  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
how much before PAS will we get it back?? early enough for me to have the one with the blue sleeves altered (massacured) into a V-Neck?
And if you get me the one with the blue sleeves leave it as the same size as the sample that fitted A1
Tying your shirt is very 80's hence nobody does it anymore and having a big nob of material hanging from ya belly aint most flattering.
Not trying to be difficult but if there has to be something distinguishing the promo girls from you guys and we have to look good...... everyone else has their promo girls in flattering nice clothes. Why didnt they tell you when they gave you the shirts that you have to order over a certain amount for it .... what is the amount .... surely theres enough guys in the club ordering shirts for their girlfriends to get an order of 20
well you said at the beginning you wanted us to be comfortable .... and the initial idea was the girls were going to choose the styles they found most flattering and do it that way ..... then decided to make it easier for you and just all get a blue singlet even tho its not what i wanted in the first place.
i want the blue sleeved shirt but only in V neck - round neck feels like your being strangled and that white singlet with blue straps looks like something my 10 yr old cousin would wear with floral leggings :(
Anyway im not the only one in this but i know that Kyles didnt find the T-shirt flattering either.
So i might as well buy my own today and that'll be one little happy camper at least ...... and thats one less girl you have to fight it out with.
Just need to tell me where to drop it.
Niz, I'm not trying to be difficult, but I have no time left, if it's not sorted out by today then they won't get done. The t-shirt would need to go to global motorsports, it's the shop opposite SST. Give it to Danny and tell him it's for the SAU order.
well i doubt they have the white with blue sleeves there so plain blue ...... try to get colour close to the other blue ones wouldnt mind it being a bit darker it'll go with white bottoms a lot better then. Look at it this way ..... least you wont have to pay for it.
Not big enough to fit the image? ..... for god sakes they are going to be the same size across ways ..... see they are going to be too big n baggy if you get a size bigger t-shirt just to accomodate the image ..... its not hard to shrink an image to 80% .... any tool can do that even i can!
Originally posted by GTS-t VSPEC
Hi Danny, Have a good weekend?
Not bad, yours would have been better :( but I will look into the TV's this week, Im not going to be here next week, back to Canberra, will be back on Friday night 10OCT03. So I have to do heaps of work before then, only week after I get back. Oh well I'll keep at it.
Paul what email addy you on ..... just got this email and it made mejust piss myself laughing
you too Strich ..... changed email systems about a month ago and i no longer hve your email addy :(
    • Given you're running a 2.8 and my 2.5 is not really like for like, I suspect there could be a bit more timing you could give it. What is the kW yield per degree you're putting through it? Here's my E85 map to give you an idea, where it was I could still get another 3~4kW per degree thrown at it.
    • It turns out that Setrab make a fan specifically for the oil cooler which is great and I've installed it with minimal swearing. I removed my 2x 12in push fans from the front of my aircon condenser and wired them into this. My main thermo fans kick on when I use the aircon anyway and would effectively already be working as puller fans through the condensor which is infront of the rad. The push fans (understandably) didn't really do much in the config they were previously in so now they're out. Now we're on to the "Oil fan doesn't really do much either!". Yes I'll duct it next if it does nothing in heavy use which it shouldn't. But hey, the object exists and fits great and is cool. Let me have this. The car is still in the "do my fittings leak oil now? do my wheels actually rub?" phase. I did a spirited drive on them and didn't hear or feel anything. Then I got back home and noticed there were grind marks on the inside of the rims, though I couldn't see where they were touching I got out the grinder and attacked the suspects. Note: I do not know how to use a grinder. Then I realised I had dragged my new rims across my concrete driveway before I did this drive. I didn't think I had damage at that time when I briefly looked...... but remembered this occurred after I did all the angle grinding. The grinding on the wheels in some very specific spots. It's not around the whole rim for example, which lines up with dragging it across concrete more than hitting a suspension component for even 1 full rotation. So everything is currently painted and taped up and I need to test it some more to see if it really IS rubbing, but from inside the car it doesn't feel like it is. In other news I attempted to do a before and after comparison of the heads/cam upgrade thing. Dynos lie, everything is in different measurements. Here is the data from the sandown back straight. Car go faster than before. Vroom vroom.
    • Here's my base ignition. +3 correction to redline when shooting water/meth which is always on. Looking at my old ignition table, I should be able to add 1-2 degree's next time I'm on the dyno.  Let me know your thoughts.
    • Given what I know now - same haha, but this was 12 years ago with second hand 740cc Nismo injectors in my S15 daily, I was too busy hunting elsewhere for the issue to even look at the injectors, running through some cleaner was a happy coincidence haha
    • Not a terrible idea. But if I ever had concerns that my injectors were sufficiently dirty to be causing me a problem, they would be out of the engine and onto the actual injector cleaner/testing bench.
