thanks Erica .... will keep you posted.
LOL @ paul learning to drift :P ...... want me to drive Friday night Paul as im not drinking anything and the Laser isnt likely to get stolen, broken into, vandalised .....
  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
god bless the public servant :P
im getting a thumpin headache ..... why am i always so tired .... i take my vitamins .... i now exercise ..... i eat fairly well :) .... yet always tired .... probably cos i dont eat enough red meat i guess.
