  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
cos im not around Alex :D
lunch was nice in the sun ..... pity its so cold n miserable back here.
things are a bit messy with my family at moment ..... doctors found abnormal cells in mum that are likely to develop into cancer ..... shes really worried ;)
haha gotta take those surrounds off. It says mistubishi!!!
Got some skylineaus.com stickers and some plate while is was down there.
'Maybe i will start being spotable now. My mates keep waving at stock looking lines just incase its me. haha
As to how i pull 204hp ... i dont know. it was my first dyno i knew fark all of what to do. i never even seen one. Got 194 and then the SST guy adjust some shit in my car and i got 204.It was heaps of fun so i will do again for sure
    • If your head gasket lifted, you should have seen a coolant pressure spike. There's no need for a copper gasket/fire rings at 30psi. An MLS with perfectly clean/flat mating surfaces should suffice.
    • I can see between the water jacket and cyl 3 there wasn't a hard line of combustion gas. It certainly appears that the issue is coming from there. Yes, checked the tension. All at 100ft lbs where I set them 5 years ago. These blocks can crack but generally when they have been over bored. Mine is only 0.5mm oversize at 89.5mm. They break between cylinders around the 91mm mark. No sign of that with mine. My gut feeling is the head gasket lifted a while back when the studs stretched and i bandaided it by retorquing the studs. It's finally let go.
    • My Nismo 1.5 churps a bit on reverse turns when cold, but besides that feels like a stock diff.
    • Yes, but, I paid cash and I'm pretty sure the receipt was in the bin 10 minutes after I got home Note to self, keep all receipts
    • Bunnings would have just handed you your money back on that one!
