  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
Ooooooohh s-13 cabriolet out front. u dont see those often.
I have almost been busted by multinovas twice today. All the positions have changed since i was last working here. So afe zones are no longer safe. Almost had an accident at lunch too.
A bus was infront of the car infront of me and he stops on labouchere rd so the cr in front of me looks like its gonna overtake and then decides not too and just sits there. I go to overtake the both of them and then at the last minute she decides to overtake and dam near sideswipes me, pushing me into oncoming traffic which looked a little worried. Thnaks to the turbo i was out of there pretty quick though, but it could have turned sour pretty easy.
ouch Boosty .... bloody indecisive females eh? :(
i havent seen a multinova in so long *touch wood* apart from on the causeway - which is where they constantly put them - god knows why in peak hour traffic you can barely do 40km/hr let alone speed!!
Yeah i almost had a big bingle about 20 cm apart!!!
just after the tunnel run. (did 3... i love the tunnel)
Some tool wanted to exit and was not on the left lane and did not check his blind spot.
I beeped rapped the skids, went under him dropped a gear florred it caught up and gave hime the finger while my mate screamed profanity... I have road rage issues.
I was thinkin the same thing. Whats the point? even though it does back their claim that its to keep speeds down not raise revenue.
Then coming through a set of lights and there is a car in the right lane which has a red light and the left lane is free but there are parked cars on the other side of the intersection. I can see the light is gonna change so i come over the line just as it changes for the perfect half dash to get in front. So the *****er at the lights guns it off the line just to block me out, forcing me to stop and let him past. What a tool. He was some bling bling looking asian mofo with a PT crusier with flames down the sides.
yeah wonder where people get their licenses ..... really doesnt pay to have a nice car cos other people just couldnt give a phuck.
Milo - im a pretty aggressive driver - expecially for a female.
    • No. Turbo shuffle and surge/flutter are not the same thing. Specifically, on a GTR, turbo shuffle has a definite meaning. On a GTR, the twin turbos are assumed to be the same thing and to operate the same way, exactly. In reality, they do not. Their exhaust sides are fed and exhaust a little differently, to each other. Their inlet sides are fed and exhausted a little differently, to each other. Consequently, when they are "working" they are often at slightly different points on the compressor map compared to each other. What this means, particularly when coming on boost, is that one of them will spool up and start producing extra flow compared to the other, which will put back pressure on that other compressor, which will push the operating point on that other compressor up (vertically). This will generally result in it bumping up against the surge line on the map, but even if it doesn't, it upsets the compressor and you get this surging shuffle back and forth between them That is "turbo shuffle" on a GTR. It is related to other flutter effects heard on other turbo systems, but it is a particular feature of the somewhat crappy outlet piping arrangement on RB26s. There are plenty of mods that have been attempted with varying levels of success. People have ground out and/or welded more material into the twin turbo pipe to try to prevent it. Extending the divider inside it works, removing material doesn't. There are aftermarket replacement twin turbo pipes available, and these exist pretty mush purely because of this shuffle problem.
    • You can temporarily* use lock collars to keep it in place until you can do the bushes, back the nuts off, slide them in, snug back up. *temporarily is often for ever
    • Thanks for the quick reply. To be clear, when you say turbo shuffle do you mean turbo flutter "stustustu" or referring to something else? I had thought they were the same thing. When I wrote the post my intention was to say it wasn't a flutter/compression surge sound. My understanding was that a flutter sound would be occurring when throttle is released, whereas I can keep the throttle in the same position for this noise
    • Hi everyone, I've been wrestling with this for a while now and have been trying to find out the cause. For context, the turbos used are Garrett 2860 -5s, the BOV is a BNR32 HKS SSQV IV kit, the car is currently tuned to ~470 whp on 17.5 psi. The car drives normally, pulls well when it doesn't happen, and I can replicate it fairly easily. It does not sound like turbo shuffle or flutter. The engine has only a thousand or so miles and has had this behavior since it was completed. After my engine was built for my R32 GTR, I noticed that the car now sometimes makes an air discharge sound on what appears to be positive boost pressure that sounds really similar to a BOV. I had thought that it was a BOV issue but even when replacing it with a brand new unit, the sound persisted. It seems like it's coming from the passenger side but I may be mistaken. The closest scenario I could find was this post here https://www.gtr.co.uk/threads/maybe-a-boost-leak-opinions.147955/https://www.gtr.co.uk/threads/maybe-a-boost-leak-opinions.147955/ started by @yakshii and it sounds very similar. As in, at partial throttle once I reach positive boost I begin to hear the same psh psh psh psh psh sound like air is leaking somewhere when I keep the throttle in the same position. It most commonly happens in 4th gear at around 3-3.5k RPM and 5th gear around 2.5-3k RPM, which seems to coincide with normal positive boost thresholds. It might be similar to what @Austrian GTR mentioned about his own HKS SSQV. Notable difference would be that when he applies more throttle when it happens, it stops. In my scenario if I apply more throttle during this repeated psh psh psh sound, the cadence of the sound gets faster and louder rather than stopping. If I lift off slightly and apply throttle again, it will normally stop and pull without issue. I've checked all rubber couplers to ensure that they are tight, but have not gotten the opportunity to properly do a pressurized boost leak test. If anyone has had similar experiences or thoughts on what might be the cause, I'd be very keen to hear them. I also have a video of it happening from inside the cabin, if that would make it easier to understand: https://youtu.be/2zqZXcx8jbA
