  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
appetite suppressants :D because i cant survive on willpower alone! and plus i get a real narky bitch when im hungry so these are keeping me human!! :D
yeah latest issue of HPI is on my desk ... but nah covered in papers i really should take down to recycling bin ... a couple of files ... a couple of instructions ... a couple of brochures and just general disorganisation which makes me look convincingly busy!
Ahh carefully orchestrated then. Im the same but i dont look busy. Got newspapers, writing pads with shit drawn all over em bits of my phone and little notes with car partnumbers and addresses on em.
Appetite supressants eh? make em ureself :D
Well depends on what its for dont it. If someone stepped on ure feet in a crowded bar than of course not but if u got stuck behind someone who is doing the speed limit in the right lane then well they have it coming dont they :D
i weighed myself Alex ...... 76kg! phuck ive never been that heavy! and summers coming ...... and auto salon etc so yeah. No Boosty they arent homemade they are the real shizzle .... my mum bought them but she got a gastro thing which these didnt help so she stopped taking them leaving almost a full bottle so ive taken them ..... work quite well too.
haha Boosty yeah i tend to scribble too .......
jeepers niz.....you're about the same height as me, and you weight 2/3 of what I do......and you're about as fat as most stick-figures.....
just be careful girly. those things are VERY addictive. both medically and psychologically.
boostzor - is the auster FF? Ca18det? and does it look sorta like the old boxy corrolas?
    • Agreed, and in particular the earth strap that should go from the subframe to the chassis but it often broken or left off. There is a section in the R32 workshop manual you can follow for troubleshooting if you don't see anything suspicious, and depending where you are (there is no location on your user profile) you should be able to get your hands on a second hand replacement unit still if needed
    • Yeah they mention as a R34 for 2.5 Turbo...but then again thos "small" were also for R34 by that different site. But i look into it and that 310mm EBC is for R34 GTT. And by those you linked the specs are the same 🙂    EDIT: I found these on one site here: DBA 4000 series T3 DBA42304S They are 310mm...and it says are for R34GTT...are there good? EDIT2: ok they have pads too.  What "color" should i get for street use? I dont want/need some noisy ones...(and if they are not that dusty that is good too)
    • Yeah, shame. Maybe  driver's carpet is available 🙏. I am waiting for both amayama and nangun to confirm.
    • Probably. I take it that they are also mentioned to be for R34 Skyline? For example.... RDA has that part as RDA7957. I have the dimpled and slotted version of that on my car https://www.ebay.com.au/itm/285518478694?srsltid=AfmBOopKxMuAFpsxZJdB1cam4D5RAj1f9yJyOttPZLAwXVNCOiwlhrIy This is DBA's top one piece equivalent https://www.ebay.com.au/itm/364246686631?srsltid=AfmBOorbb0XHQgqTvZLgQPhg70nqJtGvdojKnugum3O2LFSr2h-obp8D
    • Ok i will get those 310mm. I found one but on a different site. This is the description on those...is it ok? Technical parameters: - Axle: front. - Disc type: ventilated. - Number of holes: 5. - Disc diameter: 310mm. - Total height with center: 54mm. - Thickness (new/min.): 30/28mm. - Designed for brake calipers manufacturer: Sumitomo.
