  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
:slap: Boosty ..... becareful or you'll get a knitting needle up ya butt. Already for ya run tonight?
Cool Richie - anything you can say??
Hey Dan - you know you love my links ;) ..... unfortunately cant send it to Liz cos she's not allowed on the net at work :)
Heheh thought ud like that one. Yep shes as good as shes gonna get without me sepnding money i dont have on it. Dont expect to be too impressed it is fwd after all. I just wanna see what it can do for my own info.
Not sure if im comming tonight ..... i dont really trust taking the Laser outta the metro area and by the time i actually get the Laser to kwinana its going to be over .... soooo slow.
But be nice to see everybody .......
Ok Richie :) .... nice one dump pipe :) i should get my car back hopefully sometime next week
Tried to chase a guy in a Skyline today but i was in the Laser so pretty unsuccessful ;)
Boosty .... trust me you'll do fine .... haha i dont dare take car down to drags .... i know it'll have a disappointing time!
    • This is what the look like normally. Except we only got the 2 doors locally
    • Back pressure is not really a function of the exhaust itself, but the turbine/housing. So the question/point remains valid. I would be fitting an EMAP tapping point and seeing what is going on in the exhaust manifold before committing to throwing boost at it. Flow. No intercooler is actually rated for continuous operation at any power level wrt temperatures, as they are no actually capable of shifting the required amounts of heat on a continuous basis. They get hot during a pul, then dump some of that heat into the external air (and some back into the internal air) during off load moments/periods). You probaby do need a bigger core, given the power level you're already at is somewhat above the "rating" of the cooler. Put pressure tapping points either side of the core (which possibly you already have, if you have a boost source near the compressor outlet and tapping near the throttle for existing purposes) and report on delta P across the core.   I haven't done the mass flow calculation to see where you would be sitting on the compressor map at the ~450is rwkW level we're talking here, but if you look just at the PR you're running at, which is ~2.8-2.9, then you have a really really wide swath of the compressor map to run in, and so long as you were making between about 45-75 lb/min of flow, you should have really good comp efficiency, with the ideal being betweem 55 and 65. I can't see the need to shift drastically on the map to get better results.
    • Welcome 🙂 The ER34 wheels and slight lowering suit the R33 sedan really well. I'm firmly in the 'keep it stock, at least on the outside' camp.
    • Do this, and we'll have a resource right here.
    • "Hybrid" is a meaningless term. I could not tell you what the vendor of that turbo means by "hybrid".
