  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
Originally posted by Nizmo
you know MC did this whole thing when we had our drift day .... "oh MC isnt built for spectators ..... gotta discourage spectators etc"
Now they've got the PAS Driving event on this weekend .... and they've got it all advertised on radio to come and see it at MC
:confused: now thats a lot of advertising for a venue not built for spectators!
Niz,
I know what they said, but the reason they tried to discourage spectators is much more to do with the fact that large numbers of spectators require adequate spectator management - including risk managment assessment, crowd safety control etc.
the training day was not set up to cater for this - so I think that the real answer was that the event was not design to cater for spectators.
this event obviously has.
agh i hate that .... ask my boss if he wants me to set up tea n coffee for a meeting .... he says nah only going to go for an hour no point ..... two hours later ..... can you come up and get drinks for these people :) and bending over a boardroom table in this top was probably not a good idea!!
Yep , but only here for a short time.
Been to the accountant , the bank , waiting for someone to come then off to a Dyno Dynamics demo in Midvale.:D
* damn that avatar of Niz's is , err, disturbing *
Cheers
Ken
Nope , it's a dyno and they are setting up a new one for a tune shop in Midvale.
See a few days ago that you were gonna fly to the next drift day in the East.*sob*
This time I will leave the wookie and the fartmaster behind.
Honest...:D
Cheers
Ken
Originally posted by zanda
hey ken.
what's the money spinning business venture?
Gonna set up a pimp shop with the guys and gals of SAU working for me.
:D
Reckon it will go ??
hehe
Cheers
Ken
ps check new thread re drift day.
    • No, your formula is arse backwards. Mine is totally different to yours, and is the one I said was bang on at 50 and 150. I'll put your data into Excel (actually it already is, chart it and fit a linear fit to it, aiming to make it evenly wrong across the whole span. But not now. Other things to do first.
    • God damnit. The only option I actually have in the software is the one that is screenshotted. I am glad that I at least got it right... for those two points. Would it actually change anything if I chose/used 80C and 120C as the two points instead? My brain wants to imagine the formula put into HPtuners would be the same equation, otherwise none of this makes sense to me, unless: 1) The formula you put into VCM Scanner/HPTuners is always linear 2) The two points/input pairs are only arbitrary to choose (as the documentation implies) IF the actual scaling of the sensor is linear. then 3) If the scaling is not linear, the two points you choose matter a great deal, because the formula will draw a line between those two points only.
    • Nah, that is hella wrong. If I do a simple linear between 150°C (0.407v) and 50°C (2.98v) I get the formula Temperature = -38.8651*voltage + 165.8181 It is perfectly correct at 50 and 150, but it is as much as 20° out in the region of 110°C, because the actual data is significantly non-linear there. It is no more than 4° out down at the lowest temperatures, but is is seriously shit almost everywhere. I cannot believe that the instruction is to do a 2 point linear fit. I would say the method I used previously would have to be better.
    • When I said "wiring diagram", I meant the car's wiring diagram. You need to understand how and when 12V appears on certain wires/terminals, when 0V is allowed to appear on certain wires/terminals (which is the difference between supply side switching, and earth side switching), for the way that the car is supposed to work without the immobiliser. Then you start looking for those voltages in the appropriate places at the appropriate times (ie, relay terminals, ECU terminals, fuel pump terminals, at different ignition switch positions, and at times such as "immediately after switching to ON" and "say, 5-10s after switching to ON". You will find that you are not getting what you need when and where you need it, and because you understand what you need and when, from working through the wiring diagram, you can then likely work out why you're not getting it. And that will lead you to the mess that has been made of the associated wires around the immobiliser. But seriously, there is no way that we will be able to find or lead you to the fault from here. You will have to do it at the car, because it will be something f**ked up, and there are a near infinite number of ways for it to be f**ked up. The wiring diagram will give you wire colours and pin numbers and so you can do continuity testing and voltage/time probing and start to work out what is right and what is wrong. I can only close my eyes and imagine a rat's nest of wiring under the dash. You can actually see and touch it.
