  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
hey ken glad you put that clause in ..... no people from last day .... i think it would be painful to watch paul again ...... :D even with his magical Diff thats suddenly going to make him dooorifto master when he installs it :D .... *ducks from pauls flammin*
Don't know but if I go , it will be with a rear wheel drive , light , 300+ at the rears and a ****ing tight LSD.
Then we will see how JJ goes:shake:
Runt is just sitting out the back. May rebuild the engine and then try and sell it cos I have been getting some bullshit offers for it.
People must think it costs F1 money to fix:rolleyes:
Anyway if I go , you are invited and the rest of the troop I will consider on merit.:D
Cheers
Ken
Yea , I couldn't handle the whining...lol
Seriously , we need to give other people a shot so we have a few more to choose from for the series I HOPE they will run at the new venue next year.
Didn't say I wouldn't have an R , just wouldn't use it for the dorifto:D
Seeya and don't let those guys your going with molest you..
well molest you too much anyway:D
I'm gone too , seeya all.
Cheers
Ken
Originally posted by zanda
a RWD eh? something like a cefiro?
is the engine on Runt really that bad??
going to look at drift day thread now.......I'm sure it will make me sad - I still can't afford a ne clutch.
:D
Alex , engine on Runt is better than the one I sold Danny and that pulled 322rwhp on SST's dyno.
Trouble is I know it's not perfect and if you put it back onto the original pcv , not catch can , you wouldn't know.
Thing is I am selling to people who I may deal with later and I wan't my conscience to be clear plus I am a fussy bastard:D
Cheers
ken
We had a bizzare incident on the way home. The evoVI from the drags sidels upto this worked ute on the freeway, brakes so they're even, changes into 4th, looks for confirmantion and they're off. I leave it in forth and follow till my limiter tells me not to. Deesh in a s15 behind me does the same.
A couple of kays later (everyone one doing the speed limit), the evo pulls over onto the shoulder for the no real reason. A short while later, a spot opens up in the right lane next to the ute, so I decide to give it run. Indicate, change lanes, pull even, brake, look in the rear view mirror before I'm about to change into 3rd and what'dya know, a VY. A marked VY. Roof bar and all, right behind me. So I sit in fear waiting for the lights to come on, but instead, the cop pulls into my old spot behind the ute and pulls the ute over. Bizzare!
The cop must have seen the evo and ute race. And we think the evo must have seen the cop and pulled over early. I'm just not sure how I got out of it alive :)
    • I have more than enough digging, laying blocks, moving gravel, airrating, feeding and top soiling the grass, and setting up the veggie gardens growing some seedlings,  and then removing all the unused rock to keep me busy for the next few months at least,  hopefully the rain stops soon so I can get a few hours in this arvo, but, before that Sunday is washing day, is every body happy, you bet your life we are Nice country road day drives are a day off whenever I'm muscle sore from all the landscaping at the moment, but, more epic multiple day drives will start once the majority of the big jobs outside are completed
    • I hear that would involve some nice country road drives into the hills for Mark...
    • I thought I'd come back and add something I JUST learned. A Toyota LandCruiser with a 1HZ, mates perfectly with a bottle of Nulon brake fluid. As in, it perfectly screws in. Great make shift funnel when you cut the bottom of it off. This may work for your Corolla.   Unfortunately, tipping a 10L drum is much harder than a 4 to 6L bottle, and they no longer include the easy pour tap which was just perfection to use previously.
    • Guys since i bought r33 gts25t coupe 1994 automatic a/t(manual swap 350z gearbox)  all i got is problems, always problems. Lets start with that when i turn key into ignition(ON) fuel pump doesnt always works. Sometimes i have to turn key twice Off/on/off/on until it primes. Its new, dw300 - 340lph. My gearbox broke so i did gearbox swap, install different intake manifold, injectors and i take pipes. Car was sitting in garage for more than half a year. I did assembly all not that long ago and when i turn ignition cant hear prime. All of sudden it stopped working. Theres many videos on YouTube how to make relay mod on r33 straight from battery so i did and it doesnt work! 😰 30 - battery positive  87 - positive from fuel pump to relay 85, 86 - one of two wires from original fuel pump wires(light blue, grey) and it didn’t work. so I check on ignition and took original BLUE relays wires from trunk, next to fuses. (I believe it’s IGN+ and ECU pin 18. it didn’t work…  tried connecting (IGN+ from og relay) and (ECU 104 from 1of4 FPCM wires) to my new relay 85/86 and it didn’t work.  I unplug FPCM. Didn’t work. im thinking what’s wrong   fuel pump is working, if I leave IGN+ on 85 and 86 straight to ground it works but it’s just nonstop. Since it getting constant 12v after key in ON. light blue wire gives me 6-8v.  so how this should be connected? What causing ECU not giving — on pin? Or I did sth wrong and that’s why it doesn’t work? I need negative signal on ECU that control fuel pump. What this should be?
    • You can use your VIN to look up the factory part number somewhere like amayama, and then look to order new if necessary. https://www.amayama.com/en/genuine-catalogs/nissan Depending on price you might want to rebuild instead. @GTSBoy I had an interesting insight into US market parts when the Titan rear calipers were sticking. New calipers were dirt cheap, about 20% more than a rebuild kit....they are just considered throw away maintenance items
