  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
haha yeah ive been thinking the pink curtains arent really befitting for a bachelor pad for a while. Nah blinds are cheap tho ....... u cant put a price on ya masculinity now can ya :P
Yeah Church doesnt exactly get a great press but then again last time i went to Metros there was this huge pool of blood near the cloak rooms on the tiles there and nobody could find where it came from ...... freaky.
Sorry about double post before - had computer probs thought it didnt send.
